I have a hohner psk 75 connected to my computer via a mistar midilink usb cable. The keyboard worked fine with ubuntu 10.04 but since I upgraded to Ubuntu 10.10 it will not work. The computer recognises the keyboard as "TaHornG Musical Instrument:0" when I connect it but that's as far as it gets. I connected it to a vista machine and it said the device was working correctly. Tried all the usual forums etc. Hope you can help. Regards Bill Broadley
SOURCE: Apple mac mini/Mistar Midilink
When I first used it I had the same problem. But if you make sure the midilink OUT is connected to your keyboard IN and the IN to the OUT it might well work - mine did! It worked a treat in garageband. I am having problems now when the mac tells me that the usb device i.e. the link is taking too much power and is disconnecting it! oh well...
Posted on Aug 28, 2008
uten
  • 162 Answers
SOURCE: MFC-215C Printer may not be connected. O.S. Ubuntu 8.10
try the 8.04 cups wrapper.
see - http://solutions.brother.com/linux/en_us/index.html
Posted on Nov 24, 2008
thesuperdude
  • 97 Answers
SOURCE: Can't install Symbol LS2208 barcode scanner on a PC (Wedge cable)
You will need to scan the barcode that configures the LS scanner to use keyboard wedge or even the set all defaults barcode. You will be able to find both of this on the product reference guide that you can download from www.symbol.com in the support page.
Posted on Mar 26, 2009
thesuperdude
  • 97 Answers
SOURCE: LS 1902 AND USB CONNECTION
Scan the Set all defaults barcode from the product reference guide and set the scanner to use USB again if required. This should sort out your problem.
  • 18 Answers
SOURCE: Voyager 5929 doesn't work with Vista
The problem isn't your scanner or Vista, it's your adapter. Power requirements and speed of data require special adapters. One I always recommend is Scan Technology's part # STI-PS2-USB. I've tested it with all Metrologic scanners and it hasn't failed yet.
Posted on Apr 02, 2009
How do I get a RCA modem to run in Ubuntu Linux? The modem works in XP, just fine.
There are no drivers to operate the modem as a USB device. Using a crossover cable (one should have come with the modem), you should be able to connect to it via the Ethernet ports on your computer and the modem.
Sep 01, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need a user manual english or french for a keyboard hohner psk 75
I think you will find that this keyboard is the same as the Casio CT 680, which can be found here:
http://safemanuals.com/user-guide-instructions-owner-manual/CASIO/CT680-_E
Jul 08, 2010 | Computers & Internet
I have a Acer-AM5641-E5650A desktop and loaded Ubuntu Linux, it comes up but not able to use keyboard or mouse. I suspect I need drivers for USB devices, can you point me to a source and part...
it is quite difficult to install anything without mouse and keyboard.
try to use PS2 mouse or keyboard, it would have to work just fine, after that connect your USB devices, and it just might load the drivers need by it self
Nov 18, 2009 | Acer AM5641-B5660A Desktop PC & Monitor...
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Mistar midilink is a plug and play device but it's not working ?
You probably need the proper driver to install this. Go to the products website to find one.
Apr 25, 2009 | Computers & Internet
I'm trying to use the Sakar CR-75 Digital Card Reader to transfer photos from my telephone memory card to my computer. I've done this in the past with the same card and the same computer but now I can't...
does the same happen if you try on another computer (if it does then replace the cable or connect device directly without usb cable extension (if applicable))
if it works fine on another computer..
what happen after you plugged the device on your computer? have you try different usb ports? does other devices work fine on the same usb ports on your computer?
Dec 02, 2008 | Computers & Internet
USB mouse won't work under XP in a dual boot Ubuntu GRUB 1.5
It has the latest mouse driver (logitech setpoint 4.0). Before installing Ubuntu the setup worked w/ SUSE/XP using GRUB dual boot. After installing Ubuntu XP does not see the usb mouse. Even Logitech setpoint does not have the mouse setup/configuration option. It appears that at boot it does not recognize the mouse or disables it. The BIOS has the usb keyboard and mouse enabled. Currently, I have two mices one for xp and either mouse will work under Ubuntu.
Sep 03, 2008 | Canonical Ltd. Ubuntu
Jul 02, 2008 | Apple iMac G5 MA064LL/A Desktop
Connecting Yamaha piano (YDP-131) to imac g5
You want to go into your AUDIO/MIDI set up in OS X. Selet the unit. YOu have a MAC so most itmes dont needs drivers, its one of the many great things that separate that operating systems from say windows. Also your yamaha may be CLASS COMPLIANT, which means plug and play no matter what computer you are using.
What you should do is make sure the keyboard is set to send on the same channel as garageband is set to receive.
Keep me posted.
Dec 02, 2007 | Apple iMac G5 MA064LL/A Desktop
Computers & Internet Logo
160 people viewed this question
David Payne
David Payne
