My screen has shrunk to the middle of the screen. i have tried the horozontal screen size and theres no difference. this is happening on windows xp
  • 11,800 Answers
Simple test: unplug all the cables from the monitor, start it alone and launch the settings window of the monitor. If the image is also shrunk there then the monitor is defective, about to die.
Take it to repair shop as fast as you can, otherwise it will fail for good and it will be unfixable.
Posted on Nov 12, 2010
The keyboard on my Samsung Galaxy S4 has shrunk to about half its size, and moved from the bottom to the middle of the screen. How can I fix it?
have you tried the fingers expansion to enlarge it ---the opposite to the pinching action to reduce the size of something
Nov 02, 2016 | Samsung GALAXY S4
I need code ALLFORONE remote 4220 for Electrohome tv
These are codes for Electrohome TV: 0004 0009 0254 0003 0022
Sep 15, 2012 | One For All URC4220 Remote Control
In my windows xp the software window size is different. Vertical size in left and right is different.
Hi there.
What you need to do is to adjust the vertical placement of the screen "picture". This can be done directly on your monitor/LCD screen.
The method of adjustment is depending on the type of monitor/LCD screen.
Try to press buttons on the monitor an determine how to do.
regards
Oct 17, 2010 | Microsoft Windows XP Professional SP2
I'm using Windows XP Professional. My computer
Quick fix: Do a system restore to yesterday or whenever they last good restore date is.
We could mess around with the settings for quite a while, but I'm not really sure what has happened. Unless you clicked in the lower right hand corner of your web browser (which I assume to be Internet Explorer) and reduced the size to something waaaaay less than 100%.
Jan 14, 2010 | Dell Computers & Internet
I am having trouble with the monitor showing a black screen. It will turn off in the middle of anything I am doing, quite randomly. Using windows XP Home edition. PC does not turn off, but disk light...
I would suggest to first determine that your monitor is OK. If you are using a notebook try connecting an external monitor as well and see if the same random (monitor switching off problem) happens with this monitor. If you have a desktop try connecting a different monitor.
If the same condition happens with a different monitor try updating the drivers for your video card.
Dec 29, 2009 | Microsoft Windows XP Professional
Somehow I shrunk my Safari Window down to a quarter of a screen... I'd like to get it back to taking up close to the full screen and I don't know what to do... since I don't know what I did to shrink it.
Usually shrinkage happens when clicking the round green circle located top-left.
To fix, click on the tiny diagonal bars on the lower-right corner of the window and drag around to obtain the window size you want.
I hope this helps.
Nov 14, 2009 | Apple safari
Computer Desktop screen shrunk
1) First try to go into the control panel under display and try a different resolution. Or try to adjust the display on the actual monitor. If this does not help try Starting the Last Know Good Configuration.
2) The Last Known Good Configuration feature is a recovery option that you can use to start your computer by using the most recent settings that worked. The Last Known Good Configuration feature restores registry information and driver settings that were in effect the last time the computer started successfully. Use the Last Known Good Configuration feature when you cannot start Windows XP after you make a change to your computer, or when you suspect that a change that you just made may cause a problem.
How to start your computer by using the Last Known Good Configuration feature loadTOCNode(2, 'moreinformation'); To start your computer by using the Last Known Good Configuration feature, follow these steps:
  1. Start your computer.
  2. When you see the "Please select the operating system to start" message, press the F8 key.
  3. When the Windows Advanced Options menu appears, use the ARROW keys to select Last Known Good Configuration (your most recent settings that worked), and then press ENTER.
  4. If you are running other operating systems on your computer, use the ARROW keys to select Microsoft Windows XP, and then press ENTER.
Sep 21, 2009 | E-Machines eMachines Desktop PC
Web page has shrunk
left click your mouse on the square middle button on the top corner of the page to maximize it.
Jul 29, 2009 | Microsoft Windows XP Home Edition with...
Horozontal balck line across the middle of the screen
also check the dvd player set up menue some times you have to choose wich outlet your using like the rgb cables, s cable etc...
Mar 12, 2009 | Panasonic PT-60LC14 60" Rear Projection...
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
