Question about Canon PIXMA MP600 all-In-One InkJet Printer
Printer will not turn on, have made sure all connections are plugged in.
  • apettit380 Nov 15, 2010
    Thanks for the prompt advice. It looks like I will just purchase another printer.
    I believe the advice was sound. Thanks.
  • Canon Master
  • 11,800 Answers
Simple test to confirm the origin of the problem: disconnect all the cables except the power one, make sure the pc is closed and no memory cards are inserted then try to start the printer. If the printer doesn't start at all then the printer itself has a hardware defect.
The only thing you can check is the power pack: it's at the bottom of the printer, the power cable plugs in it. Take it out by unscrewing the 2 security screws, plug the power cable in it and in a mains socket then verify the voltage at the output contacts with a voltmeter. If no voltage is present then the power pack is dead and must be replaced. If the power pack is active then the printer itself is defective. In that case it will be more economically sound just to replace the printer - fixing it will cost you almost as much as a new one.
Posted on Nov 12, 2010
  • dougm007 Dec 15, 2010
    Of course there is always a chance something on the printer has failed that damaged the power supply. So if you bother to buy a new power supply, you might immediately damage the new power supply plugging it in to the same printer. Is it worth the gamble? Humm...
Error c410, is it a serious problem ie costly to fix or how easy itto fix it?
That is a general printer error. Ensure that the cables are properly connected; you need to ensure that your printer is properly connected, and plugged in, and also the cable is accurately connected to the computer as well. Check the power; make sure that the printer's power is switched on, ensure that all the computer necessary computer components are also turned on. Make sure that the hardware is properly plugged in.
Jul 04, 2012 | Office Equipment & Supplies
Printer is saying cant communicate with pc??
Make sure that the hardware is properly plugged in, and also turned on. Apply troubleshooting.
A troubleshooter is a tool, which is generated automatically and which can easily fix the problems that occur with your system.
Thus, if you are coming across different issues related to your printer, then you can consult the troubleshooter.
You require driver applications to run your hardware devices.
Make sure that the drivers are not outdated, corrupt, or incompatible, resulting in disrupting the communication between the printer and the computer.
Always make sure that you are making use of the most recent and latest device drivers, and also that are compatible with your system requirements and specifications, as this can be extremely useful in resolving printer issues.
Jun 01, 2011 | Canon Pixma iP2700 InkJet Photo Printer
My printer is not work with the connection woth my computer
May 09, 2011 | Canon PIXMA MP830 All-In-One InkJet...
The printer is switched on at the plug and all connected but the printer wont turn on when clicking the on/off button on the actual printer. what can i do?
Is there a power light on the power brick? if not make sure the power brick is plugged in all the way. Try plugging a lamp or a light in the socket and make sure the not the outlet.
Still having problems try a different outlet.
If there is power going to the printer make sure the connection between the power and the printer is firmly in.
Mar 07, 2011 | Lexmark X2350 All-In-One InkJet Printer
Cant get my computer to connect with my printer
Feb 15, 2011 | Dell 1815dn All-In-One Laser Printer
My printer won't print. It's plugged into my computer, and it says it's ready to use, but then it says error.
Nov 25, 2010 | HP Deskjet 6940 InkJet Printer
Paper jam
Hi Good day!! Follow this method to remove your paper jam:
1. Check to make sure that the power cord is securely plugged into an active wall outlet if your printer is not turning on.
2. Make sure that the USB cable connecting your computer to your printer is securely connected if your printer powers on but will not perform a print job.
3. Remove a paper jam if the "Check Paper" light on the front of the printer is blinking. To do this, first turn off the printer and unplug the power cord from the printer. Open the front cartridge door and locate the jammed paper. Gently pull the jammed paper toward you. Plug the printer back in and turn it back on.
4. Connect your printer to a different USB port on your computer if you are experiencing slow printing. The slowness could be due to a connection problem with your computer's USB port. After you've switched the port, try your print job again.
5. Make sure that a phone line is securely connected from a phone jack to your printer if you are having trouble sending or receiving faxes.
6. Clean the scanner surface if your scans are blurry or have vertical white or black lines. To do this, spray the a soft, lint-free cloth with a mild glass cleaner. Wipe the scanner glass with the cloth and then dry it with another clean lint-free cloth.
7. Hard reset the printer if you are having trouble solving your problem. Turn the printer off and remove the power cord from the wall outlet. Wait at least 15 seconds and plug the cord back in. Power the printer on and try your job again.
8. Restart your computer if you can't solve your printing or scanning job. Sometimes restarting the computer can solve an unseen problem.
Don't forget to vote thanks!!!
Oct 28, 2010 | HP PSC 1510 All-In-One InkJet Printer
Cannot turn on the printer even if connections are ok ?
The only thing that could stop you from turning the printer on other than a broke printer is the power/power cord is not connected. The printer should turn on without a USB or parallel printer cable attached.
If no lights are showing when you try to power the printer, check the power connection in the back of the printer to ensure it is plugged in, check the plug into the adapter is connected and that the power cord's plug is connected to the wall outlet - if you have a power strip make sure it is turned on and the circuit breaker is not popped. Make sure that there is power to the outlet by plugging in something else to show it has power. If all of those check out ok and you have a meter, check for voltage at the power connector at the printer (pull the plug out of the printer and check voltage from inside the plug to outside the plug. It should be 18 vac.
If all of this is ok, there is something wrong inside the printer. Probably time for a new one as cost to repair is probably too high.
Oct 11, 2010 | HP DeskJet 810c InkJet Printer
R800 won't turn on
1. make sure all power cables are securely connected.
2. check connection to pc from printer.
3. Plug the printer into different outlet (one can go out while others still operate normally, it happens!.....even on a surge protector!)
Apr 19, 2009 | Epson Stylus Photo R800 InkJet Printer
Problems with printer
try to check the USB cord between the printer and the PC if it is connected...
Mar 27, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
309 people viewed this question
old marine
old marine
