Question about Panasonic NN-S254BF Microwave Oven
Panasonic NN-S254B How fried is it?
Earlier this year I cut a tree down and it fell on the power line yanking the neutral wire from the mast at my summer cottage.
Consequently my whole cottage had two hots and no neutral. I fried a Satellite receiver, clock radio, cordless phones and my Panasonic Over the Range NN254 Microwave.
Oddly the TV survived.
There is power to the receptacle that the microwave is plugged into but there is absolutely no sign of life in the microwave when I plug it in.
Do you think this is just a fuse or is the whole unit junk?
I can buy a new microwave for $200
The microwave is 100 miles from me right now
  • 100 Answers
There is an internal fuse, so check that first. If the fuse checks ok, definitely buy a new microwave - losing a neutral usually damages the main circuit board. Given the cost of the board and the distance involved, it just wouldn't pay to chase the parts down
Posted on Jun 30, 2008
Panasonic NN-SN960S, turntable won't stop spinning. Have to unplug after every use. What kind of repair does it need and how much would it cost?
May be a door switch problem, or may be a control board problem. You might even have a shorted wire that goes to the turntable motor. (I have seen 1 of the wires get pinched and cut by metal guards or guides that were meant to keep the wires in place.) You can remove the screws from the bottom of the microwave oven, and drop the bottom panel down to checked for pinched wires. Unplug the microwave first before you do that.
Oct 18, 2014 | Panasonic NN-SN960S Prestige Stainless...
JVM1750sm1ss micro-oven, totally dead when plugged in.
see the diagram and proceed with common sense use the VOM
God bless you
7_17_2012_2_10_43_pm.jpg7_17_2012_2_11_13_pm.gif7_17_2012_2_11_40_pm.jpg7_17_2012_2_12_03_pm.jpg
Jul 16, 2012 | Microwave Ovens
I have a Panasonci NN-SD686S and after a power cut last night, the microwave is now in demo mode. After power cuts previously this has never happened, and I can't find anything in my manual to...
To set Demonstration Mode: press micro power once, then press Stop/Cancel 4 times. To cancel Demonstration Mode press Micro power once, then press Stop/Cancel 4 times.
Sep 09, 2011 | Panasonic NN-C994S Convection/Microwave...
I want to change the light in my microwave. Panasonic nn-p704sw. I took apart the covr and foung the light attached to a plastic scockrt. I tried to unscrew but the bulb was tight. should i apply more...
Typically the bulb will unscrew from the socket. If you can remove the bulb and socket with the wire from the microwave (wire hanging from the microwave) you might be able to get more pressure on the bulb to turn it. Keep in mind that the bulb may have been in the oven for several years and there may be a build of grease on the treads of the bulb so it could be really stuck. Put a cloth towel around the bulb and wear gloves so you don't cut your hand if the bulb were to shatter.
May 02, 2010 | Panasonic NN-P794SF Microwave Oven
Microwes panasonic nn-t553w
hi, check that the cooling fan is operating and to sufficient speed to cool the magnetron or the thermal cutout mounted to the magnetron will cut power
Mar 06, 2009 | Panasonic NN-S753 Microwave Oven
Stopped heating, shuts off before time expires
My panasonic microwave model # NN-S540BFW stops after 4 seconds after you hit the start button and cuts off on its own. What is wrong with my microwave?
Jan 12, 2009 | Panasonic NN-S763BF Microwave Oven
No power to the unit, fuse tested fine, outlet is working
Sorry, but your subject line got cut off.
Assuming the outlet is fine, it may be a thermal cutout / thermostat on the magnetron or on top of the cavity.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 02, 2009 | Panasonic NN-H764 Microwave Oven
Cuts off know heat
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Nov 13, 2008 | Panasonic NN-P794SF Microwave Oven
PANASONIC INVERTER MICROWAVE, 1300 WATTS
  1. Same exact problem
  2. I've noted 3 different ones with the same problem
  3. Panasonic has produced a lemon, north fixing
Mar 27, 2008 | Panasonic NN-T694SF Microwave Oven
Panasonic NN-S254BF Microwave Oven Logo
106 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
