Question about Lexmark Z715 InkJet Printer
White lines through print jobs. installed new cartridges
    Genius:
  • 1,087 Answers
It could be the cartridges in the printer. Maybe it needs cleaning. Refer to this article How to Clean the Cartridges of the Lexmark Z715 in Windows. If problem continues, reseat the cartridges. Or you can try to use a different known working cartridge to determine if the other is faulty. Thanks.
Posted on Nov 12, 2010
Why am I missing colors on prints
Could be the print job you send to the printer is set up to print in black and white.
Or the cartridges are full and the nozzles from the printhead are blocked.
Run a cleaning cycle on the printer. If some colour appears continue till all colours are back for all nozzles.
If you did not use he printer for a long time, remove the cartridges one by one and put a drop of cleaning fluid in the pipes in the cartridge holder (where the ink goes in) tun replace the cartridge and print one or two full sized colour photos, till all colours are back.
Jul 26, 2014 | Kodak ESP 7250 All-in-One Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I do not know how to change my printhead on my HP Officejet Pro L7580
---Make sure the printer is on, or press the Power button to turn it on. Wait for the printer to finish any warm-up diagnostics or print jobs it is performing.
---Open the access cover to the print heads. This cover may be the top cover, the front door or an ink access door on the front of the printer.
---Wait for the cartridge carriage to stop moving, making sure it is completely stationary before putting your hand in the printer. Lift up any clips or latches keeping the print heads or cartridges in place.
---Remove the old print head or ink cartridge if it is part of the cartridge, and discard it. Remove the packaging from the new print head, making sure to peel off any protective tape or twist-off protective caps.
---Insert the new print head or cartridge into the empty slot. Lower any clips or latches and make sure the print head or cartridge does not wiggle in its spot, otherwise you need to pull it out and reinsert it into the printer.
---Close the cover you opened to access the print heads and wait for the printer to calibrate the new print heads. Some printers may produce an alignment page, which you can throw away.
***If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Apr 04, 2013 | HP Officejet Pro L7680 All-In-One Printer
Have an MD 1300. printer begins then stops before actually doing the job. Get message: "cartridge change error - cannot complete print job." I have tried putting in a new cartridge but same...
What color are the cartridges that you are putting in? Are they blue or are they greyish in color? If you are trying to print on laser or other such paper, you need to be using the greyish cartridges. Also make sure that the cartridges that you put in have plenty of ribbon in them and that you've put them in facing the correct direction, you should be able to see the color names when you open the printer. If you don't, you've installed them facing the wrong way. Also make sure that you have all the correct colors installed for the print job. Unless you're printing strictly in black and white, you'd be surprised at what colors are needed to make a color, unless you're using pure Cyan, Magenta or Yellow. Any colors other than those will need to use a combo of those colors to reproduce colors properly. I hope this helps. If not, write back and say what steps you've followed to try to remedy the error.
Nov 18, 2010 | Alps MD 1300 Thermal Printer
I have installed new cartridges the colour prints perfect but the black is blurred with lies through it. i also found a small t shaped rubber piece about about 4mm x 6mm in the paper tray could this be the...
this rubber piece can be actually locket from printer rollers, but, returning to your smudgy printing
1. remove cartridges from the printer
2. check if there is bit of paper stuck anywhere in paper path, if so, remove
3. check if rollers on paper path are clean
4. touch bottom of the cartridge with absorbent tissue to check if ink is flowing through, if yes then insert cartridges back and print test page.
5. if cartridge do not allow inkflow, check what solvent is used (water, isopropyl alcohol or methylated spirit - this which do not cause precipitation is correct solvent), soak absorbent paper (tissue) with proper solvent and whipe head of the cartridge with it, 6. put drop of the solvent on golden knobs inside seats of the cartridges of the printer, allow it to soak in, wipe off with lint free tissue and put another drop of solvent in. allow soak in,
7. install cartridges back, print test page, it should start printing very weak and improving as it goes through the page (solvent will be printed first)
8. create "strip page" one line yellow, white space, one line cyan, white, magenta, white, black - print that page, this print will clean printheads and establish good inkflow.
all ink printers must print at least one page per week as to keep heads free of gum and ink in flow.
Jul 28, 2010 | HP PSC 1610 All-In-One InkJet Printer
Install color cartridge
You have to clear out your print queue from the computer.
The last print job you sent was set to color and so the printer now believes it needs color to print.
First you will need to unplug the power to your printer.
With windows, you need to go to your "start menu" and select "control panel" and then select "printers"
Double click on your printer icon and cancel any print jobs.
Now you can turn your printer back on.
For any future print jobs, you need to make sure you are printing in black and white.
Mar 26, 2010 | HP PSC 750 All-In-One InkJet Printer
How do i change an ink cartridge on a HP PSC 1510 printer
To replace the print cartridges
1. Make sure the HP All-in-One is on.
Caution If the HP All-in-One is off when you lift the print-carriage access
door to access the print cartridges, the HP All-in-One will not release the
cartridges for changing. You might damage the HP All-in-One if the print
cartridges are not docked safely on the right side when you try to remove
them.
2. Make sure the paper tray is down and there is letter or A4 unused plain white
paper loaded in the paper tray.
3. Open the print-carriage access door by lowering the door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then, using your thumb, lightly press down on a print cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge
5. Pull the print cartridge toward you out of its slot.in-One
6. If you are removing the black print cartridge in order to install the photo print
cartridge, store the black print cartridge in the print cartridge protector.
7. Remove the new print cartridge from its packaging and, being careful to touch
8. Slide the new print cartridge forward at a slight upward angle into the empty slot.
Using your index finger, push the print cartridge forward until it clicks into place.
If the print cartridge you are installing has a white triangle on its label, slide the
print cartridge into the slot on the left. The label for the slot is green with a solid
white triangle.
If the print cartridge you are installing has a white square or a white pentagon on
its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon.your HP All-in-One
9. Close the print-carriage access door.
If you are installing a new print cartridge, the HP All-in-One begins to print a print cartridge alignment sheet.
10. Load the print cartridge alignment sheet on the right front corner of the glass with the top of the page to the right.
11. Press the Start Scan button.
The HP All-in-One aligns the print cartridges.
Good Luck.
Apr 10, 2008 | Office Equipment & Supplies
Printer lines in photo's
Click Start - All programs - HP - HP Solution center.
In HP solution center Click on the Printing Shortcuts tab. Select Photoprinting with borders or borderless. Click OK.
Then close the HP solution center. Try printing. Print photos always with Best quality.
If the issue persists check the ink level of both cartridges and use Photos Cartridge HP 58 to print photos. We insert the Photo cartridge in place of black cartridge.
Thanks
Dec 19, 2007 | HP Officejet 5610 All-In-One InkJet...
White lines appearing on print
White Lines on the Printed Page ID:193 null.gif null.gif null.gif
Clean the print nozzles as follows:
  1. Go to Start, Programs, Lexmark, Lexmark Solution Center (or Lexmark Control Program) and select the Cartridges tab.
  2. Select Cartridge Nozzles (or Clean Print Nozzles).
  3. Check the diagonal lines above and below the solid horizontal lines. The diagonal lines should be continuously solid from left to right, with no gaps.
  4. If there are gaps at the top that diminish at the bottom, run the Clean Print Nozzle page a few more times. If the gaps are gone, the Clean Print Nozzle page has probably resolved the problem.
  5. If the gaps still exist, you should unblock ("wick") the cartridges. See How to Unblock/Wick the Cartridge Nozzles.
    For additional help, refer to the following article: How to Clean the Maintenance Station .
Nov 10, 2007 | Lexmark X5470 All-In-One InkJet Printer
My magenta will not print well
Here's what you should do. Remove all ink cartridges. Get some rubbing alcohol, preferrably 91% proof (leaves less moisture) Get a couple normal paper towels. Check each cartridge for dried ink and remove it using an alcohol wetted paper towel. (The deep cleaning procedures aren't always effective.) The gold contacts on each cartridge should be gold when you are done. Use the same procedure on the gold contacts of the ink cartridge housing inside the printer. Take your time, do it well. If that does not fix the problem, then do the following. Switch the black and magenta cartridge. Some printers won't print when you do this, other printers don't know the difference. If your printer is the later, then attempt a print job using a page that has a line of both black and magenta text. If you see a black print, then the problem is your magenta cartridge (despite having installed a new one) If the magenta prints, then you know the magenta cartridge is good. If the magenta prints but the black doesn't, then you have a printer failure. Let me know your results. ZT3000 Beta tester of "0"s and "1's"
Aug 18, 2007 | Canon i860 InkJet Photo Printer
Lexmark Z715 InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
