Question about Yamaha Full-Size Keyboard
Yamaha P120 S. I have got a replacement keyboard from Yamaha but can't figure out how to fully open the case to remove the unserviceable one and fit the new one. I have removed most of the screws from the bottom of the instrument, and managed to slide the right-hand end cover out of the way, enabling me to pull one end of the front cover outwards. But I can't see how to get the left-hand side out. Can you help please? Thank you.
What is the part number for the replacement keyboard? i need to replace one as well. Thanx
Posted on Feb 14, 2011
Yamaha psr700 speaker cover removal
Assuming this is a PSR-S700 then you need to undo all the screws under the keyboard and open up so you can see inside under the speaker grill. You will see the grill has tabs that poke through the casing and these are then twisted to keep it in place. Straighten these, push tab through casing going from side to side and then the grill will eventually work free. You do not want to do this too much as the tabs will eventually break with wear.
Jun 18, 2016 | Yamaha PSR-S500 Digital Keyboard
Yamaha p120
might have them to close togeather
Jul 23, 2013 | Music
Yamaha psr 550
When PSR550 keys stop working, or are intermittent, in any arrangement, this can be fixed (with work). There is probably TINY dust or debris which prevents a clean key contact from taking place; you must unscrew and open the PSR550 up like a ****, then unfasten the bottoms of the keyboard circuit boards. You can figure out how to move them without totally disconnecting them. You will observe how a tiny rubber-mounted contact presses against an interleaved circuit-board connection pattern to make contact when a keyboard key is pressed. Any dirt or crud on the contact area of the circuit board must be removed, because it will prevent the conductive contact from bridging the circuit cleanly and fully. I used 91% alcohol and QTips to clean all contact surfaces. It took me a couple of disassemble/assemble cycles to get all the keys clean and working, and the PSR550 back together. But first download the service manual: it will show you how to open it and access various components. You will see that the keyboard switches are much like calculator buttons on a TI-83 calculator. They are pretty well enclosed, but you will see how much dust can settle in just through various humidity conditions, especially if you take it to gigs. Good Luck.
Nov 24, 2011 | Yamaha Music
Looking for music stand that fits on top of p120
These are sold online at Kraft Music
Yamaha WB53080R Music Rest
Replacement Music Rest for P120, P140, P155, PF500, PF1000
Jun 24, 2010 | Yamaha Music
I am getting the error message scn on my p120 keyboard and there is no sound from the keyboard.
Just bought a P120 from craigslist. A computer recycle company was selling it as parts for $150. They said it has the SCN error code and the keys don't play. It played the demos only.. Payed $100; took it home, opened it up & found the keyboard plug had detached from the motherboard. Plugged it in & BAM! It works just fine.
Oct 18, 2009 | Music
I need to repair a sticky key on a P120. Is there a repair manual?
Call around to local music stores and ask about the closest authorized Yamaha repair center. If it is still under warranty, they should replace the keybed free of charge.
Here is a great website with the do's and don'ts about self keyboard repair. http://www.mikebarden.com/view.php/area/1/digital-piano-repairs-keyboard-repairs
Sep 17, 2009 | Yamaha Full-Size Keyboard
Keys sticking on Yamaha p120 digital piano....how do I open it up
you may not need to open it up.
try using a wax based furniture polish on the keys, it will leave a layer to act as a lubricant between the keys.
Aug 24, 2009 | Yamaha Full-Size Keyboard
What needs to be removed from my Yamaha YPG-625 to
DO NOT open the case unless you are aware of and comfortable with the fact that you could _destroy_ your piano. Easily.
Observe appropriate anti-static precautions. It should go without saying that this is an electronic repair, and dangerous voltages may exist inside the case.
1. Remove the stand if you have one
2. Lay the keyboard upside down (bottom up) on workbench
3. Remove all 90+ screws from the bottom of the chassis, including the 14 inside the speaker compartments
4. Carefully lift up on the bottom case part, taking not to damage the speaker lines
5. Unplug speaker connector and set lower case aside
6. LCD is mounted beneath main logic board
9in the center), my problem lies elsewhere, but competent and cautious service technique should lead you where you need. I would strongly recommend replacing the LCD assembly module, unless you are experienced in LCD repair.
Jul 06, 2009 | Yamaha Full-Size Keyboard
How doI open a Yamaha P120 to fix sticky keys?
I've had the very same problem twice so far. The only solution I figured is to simpy purchase an equivalent key (contact Yamaha service in your country for this) and to replace the broken one. The reason why the key doesn't work smoothly as the other one is not dirt therefore any cleaning won't help. The key is cracked deep in the place where it's attached to its 'axis'. So you'll need to remove all the screws and unmount the cover (it needs a sideshift to open once the screws are removed), be careful with the speaker wires. However you'll need firm moves anyway. Opening is tricky and gets me surprised anytime I do it so you'll need some courage :). Replacing the key is even more tricky. You'll have to remove the broken one by pulling it horizontaly (use some force, it's broken anyway). Placing a new key you'll need to uplift the 'hammer' and then slide a new one. I'm sure you'll figure it out once you see it with your own eyes (it's really hard to decribe but not so hard to do it). Hope you'll do fine. I haven't tried glueing the crack for I doubt it would work for long. Good luck!
Jan 28, 2009 | Yamaha Full-Size Keyboard
Yamaha Full-Size Keyboard Logo
231 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
