Question about Canon iRC3100 Printer
How to remove the drum unit. please give me the direction with figuers. Error E0020-0081 & please provide me error codes details
  • 3 Answers
HELLOW SIR MY NAME IS ASLAM SORRY SIR I HAVE NO FIGURES IN UR MECHINE ?SO FIRST U WILL OPEN THE FRONT DOOR AND TAKE A SCROO DRIVER U WILL LIVE A UNIT OPEN THE 3 SCREW S U WLL CHANGE UNIT
Posted on Dec 04, 2010
Error code r80
what is the equipment that is giving you this error?
Drum, Transfer Belt and Fusing Unit Firmware Reset - http://www.bizhubreset.com
Drum and Toner Chip Reset - http://www.chipreset.eu
Transfer Belt and Fusing Unit Reset Kit - http://www.resetkit.eu
Konica Minolta Error Codes & Solutions - http://www.kmcodes.com
Aug 21, 2014 | Office Equipment & Supplies
E003
What is the equipment that is giving you this error?
Error code H5-01 and the coppier doesn't start
H5-1 means, the copier jammed more than 2 times at the fuser unit. Check the unit if any the fingers are ok, check if the fuser gear is ok. Inspect if fuser rollers condition. Once you figuer out the problem, you need to reset the error code. The procedure of resetting error codes depends on the model.
Dec 06, 2013 | Sharp Office Equipment & Supplies
Canon IR C3220N--error code E000020-01b0
If the drum units have been removed repeatedly without the drum guide service tool it's possible to break one or both tabs .These tabs open the toner hopper when the drum unit is slid in, and if they are broken, toner will not be fed into the drum unit.
NOTE: The unit may work for a while until the developer to toner ratio drops enough to cause an error.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Canon imageRUNNER C3200 Color Printer
I have an e 000012-0002 error on my ir 3100 - can you help please?
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
Oct 02, 2009 | Canon imageRUNNER C3200 Copier
F33 error code. drum begins to rotate and then
The F33 error code indicates a pump drive system error. If the pump ohms out correctly & the harness is secure I recommend replacing the CCU (central control unit).
Please see the following image provided for instructions.
http://media.fotki.com/1_p,stwwfrggtqfbrbbxgtqsskgwtqkq,vi/wgtbwqwssxsbwkbdtfwxrbfbddwwf/1/1303472/5961857/image9159087223444281043img-or.jpg
Remember to disconnect power to the washer before attempting access.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 06, 2009 | Kenmore HE2 Plus Front Load Washer
Error E100
The most common cause for E100 is the drum unit. At the rear of the drum unit should be a small peg pointing into the machine. This gets broken off. It's purpose is to opperate a laser cut off shield when the drum is removed so to prevent laser exposure. If peg is missing laser will not be detected by the system and give E100. Can be repaired or will require a new drum if it has done more than 40 to 60K copies.
Dec 31, 2008 | Canon PC-1060 Black and White Copier
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Sep 11, 2007 | Ricoh Aficio 2016 All-In-One Laser Printer
Canon IR 2000
Canon IR 2000
System Error E100
Feb 27, 2007 | Canon imageRUNNER 2000 Copier
Canon iRC3100 Printer Logo
123 people viewed this question
old marine
old marine
