Question about American Standard One Handle Shower Only Faucet 2000.501.295
I have an American Standard shower that drips out the shower head. When other faucets are used in the bathroom the water pours. I replaced the cartridge put it still drips.What could be the problem?
  • 26 Answers
Hi kwbaker!
Assuming the cartridge is new and the water drips at both hot and cold settings, I would check your shower head. It is not uncommon for debris to collect in the screening there and clog the spray nozzle.
To check the shower head you'll need to remove it from its piping. Use two tools--I normally use an adjustable wrench and a strap wrench--to hold the wall pipe and simultaneaously turn the shower head counter-clockwise. The cresecent wrench grabs the hex-head of the shower head, while the strap wrench holds the chromed piping without scratching it.
Be sure you don't lose the rubber washer inside the pipe-to-shower head connection!
Once the head is removed, look inside it at the pipe side. You should be able to see into the mechanicals of the shower head--very often I'll see bits of rust or scale. Oftentimes its enough to rinse the pipe side of the head under a sink; in extreme situations it can be easier to replace the entire shower head.
To replace the shower head, use two tools in the same manner in which the head was removed: crescent wrench to turn the shower head, strap wrench to hold supply piping. This time, however, turn the shower head clockwise until it tightens snug.
Hope this helps!
--Joe
Posted on Nov 27, 2011
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
My american standard shower is sending water from the shower when using the tub faucet
Probably a defective, corroded or half stuck diverter. This is the part that diverts the water either to the tub or shower. Disassemble, inspect, repair or replace.
Dec 04, 2014 | American Standard Plumbing
No water flow from new american standard marquette showerhead
I think fitting of your shower is not proper. You have to fit it properly if you can or you can call a nearest Plumber to solve your problem.
Mar 13, 2014 | American Standard Home
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
Water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
Jun 14, 2009 | Water Pik WATERPIK SHOWER HEAD COMBO PACK...
Slow and nonexistent water flow.
Start by removing the spray head from the hose. Pull the spray head out and with a channel lock pliers unthread connection between the spray head and hose. BE CAREFUL not to let the hose fall back down into the faucet. With the hose directed down toward the sink test for volume by turning on the faucet. If you get a nice volume the problem is in the spray head. This is usually the case. Put the spray head back on then remove the aerator. It's the screen where the water comes out of the spray head. Clean out the assembly ( 3-4 parts). Reassemble and test.
Good luck, Phil
Dec 11, 2008 | American Standard Bath Faucet Ceramix...
American Standard One Handle Shower Only Faucet 2000.501.295 Logo
299 people viewed this question
Top American Standard Plumbing Experts
Donni Steen
john h
TED
Level 1 Expert
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
