Question about Zenith XBV243 DVD Player/VCR
Stuck with progressive scan mode
Ok so i was trying to fix somethign with it..and so i clicked setup on the remote that came with the dvd/vhs and then i like clicked some other thing and then a thing poped up saying "PROGRESSIVE SCAN MODE"
so then i was like clicking setup and nothing would come up. so then i turn up the volume and i could here my dvd running its just i oculdnt see wat was happening. PLEASEEE HELP MEEE!!!!!!!!!!!!!!!! i wanna watch my one tree hill on dvd!!!!!!!!!!! THANKS SOO MUCHH!!! <33
  • Geanss Jun 18, 2008
    yea im u u ideot! lol
    haha
    im u u ideot!
I've had the same problem. Press and hold the 'stop' button down on your remote for five seconds (make sure you've clicked 'setup' off) until the main play screen (in my case the opening play screen for my Zenith player) appears. You'll be fine after that. Just stay away from the 'progressive scan' - it's a feature you probably don't need, anyway.
Posted on Nov 01, 2008
    Genius:
  • Zenith Master
  • 1,550 Answers
My dear friend try with this,turn on the dvd take out the disc open the tray now push for 5 seconds the button stop.Good luck.
Posted on Jun 19, 2008
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
DVD/VCR Combo - Zenith XBV342 Stuck In Progressive Scan
mi zenith xbv342 solo queda la pantalla azul y dice progressive scan mode como salgo de hay
Jun 14, 2009 | Zenith XBV442 DVD Player/VCR
Picture is split -- says P-SCAN. It's stuck
that means it is stuck on progressive scan.  If your tv is not able to handle progressive scan, you need to change it back or reset the player.
The DVD player may be set to Progressive Scan Mode. You will need to change it to Video Mode by using the remote control. Point the remote control directly at the DVD player, and then press the PSCAN button 2-3 times. If you are still encountering problems with the DVD player, reset the unit back to the default setting.
To Reset,
Make sure you do not have a disk in the tray. Using the DVD player remote control: 1) Press the “Setup” button. 2) On the “Down” arrow, press it three times. 3) On the “Right’ arrow, press it once. 4) On the “Down” arrow, press it three times. 5) On the “Right” arrow, press it once, then press “Enter”. 6) Press the Setup button. *The default setting will take affect as soon as you press the setup button (step 6).
Hope it helps..please rate!
Mar 07, 2009 | Coby DVD-224 DVD Player
I hit setup and i clicked something and then my problem occured.
Try pushing the OUTPUT SELECT button on the DVD remote.
This button Cycles through the 3 main output views:
DVD, Tuner and VCR.
Jun 18, 2008 | Zenith XBV243 DVD Player/VCR
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
GOLDSTAR DVD/VIDEO PLAYER
Remove any discs from the unit. Make sure your tv is on the blue screen. It should say "Progressive Scan Mode"....After removing the disc(s) from the disc changer, close the changer, press and hold the stop button on the unit, not the remote, for 5 seconds or more and it will reset to normal playing mode. Progressive Scan is typically only for TVs that use Progressive Scan....most normal TVs do not use progressive scan mode. Hope this helps...It worked for me!!!!
Jan 20, 2007 | Goldstar DV7411N DVD Player
Locked into progressive scan AND Setup is Unavailable
The key is to make sure you REMOVE all DVDs and VCRs from the player, then hold the stop button on the unit down for 5 seconds.
Oct 23, 2006 | Zenith XBV442 DVD Player/VCR
Stuck in progressive scan mode
You need to be sure to remove the discs from the disc changer and close the disc changer. Make sure that your TV is on the Blue Screen and it should say " Progressive Scan Mode" Press and hold the stop button on the unit....not the remote for 5 seconds or more and it should reset. However, if your TV is a Progressive Scan compatible TV, you may need to refer to the user guide for the TV as well....Many newer TVs Use a Progressive Scan Setup, but this solution should still work for you. Make sure all discs are removed FIRST!!!
Aug 29, 2006 | NexxTech ESDVD100 System
Zenith XBV243 DVD Player/VCR Logo
57 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
