Question about Indesit W 123 Front Load Washer
Indesit IWDE7145S pre-chamber lid is stuck. Doesn't budge?
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: drain
Check the hose from the pump to the outlet, sometimes it can get blocked.
Make sure you can hear the pump working, you should be able to hear it running.
Hope this helps.
Posted on Jan 15, 2010
SOURCE: pump pre chamber lid wont open
I have a PWE8168 and assuming yours has a similar arrangement:
1) Switch off water and electricity feeds;
2) Pull the washing machine forward a sufficient distance to allow you to tip it back so that you can gain access to the area next to the pre chamber lid. I found my tool box was handly at propping up the front!
3) A torch is handy at this point. Lie on the floor, and use a pair of mole grip pliers to release the springs securing the pipe attached to the left of the pre chamber filter (looking from the front of the machine).
4) Note that if you have not been able to drain your machine already your should have some towels/cloths and (eg) a tuppaware container ready to collect all the water.
5) Slide the pipe off and you should be able to get your fingers into the pump pre chamber and fish out whatever is jamming both the pump and the lid. I got a 5p piece for my troubles!
I would not say that this is a particularly difficult procedure and apart from water collecting, should only take 20 minutes, including reconnecting the pipe.
Posted on Mar 04, 2010
Please can you tell me what the pressure switch is?
this is a unit with a pipe from the pressure chamber on the drum to it .you find this near the lid area
this tells the machine when to stop filling water in to the wash drum. a
Jul 12, 2014 | Indesit IWDD7143 Washer/Dryer Combo Front...
Honda Accord 1993 EX is stuck on Park. It doesn't budge if I start the car and it doesn't budge if i try to shift to N,P,D4,D3
Use your ignition key and stick it straight down into the slot marked shift lock, next to the shifter. That will allow you to shift it into neutral. Leave it there, remove the key from that slot and start the car. You will then be able to shift into drive, from neutral, and be on your way.
Jun 26, 2011 | 1993 Honda Accord
HELLO MY WASHING MACHINE WM12X INTEGRATED INDESIT MACHINE WAS SPINNING AND WE HEARD LOUD BANG ... THE WASH FINISHED OK BUT NOW THE DRUM WHEN EMPTY SEEMS TO BE "CATCHING" WHEN SPINNING BY HAND. ...
open the back door try to remove the belt and then try to rotate the drum by hand if it stuck again you need to check if there is something between the drum and the chamber
Jun 10, 2011 | Indesit W 123 Front Load Washer
Drain
Hope this helps.
Jan 14, 2010 | Indesit Washing Machines
Won't spin on last cycle
The pump is supposedly self cleaning.
There's a 'pre-chamber' behind a panel at the bottom on the front. The top of the panel should tilt forward & up. Turn the 'pre-chamber' anti clockwise, after putting a shallow tray under it to catch the small amount of water that may be there.
I think I have a pdf manual (found on web somewhere) on another computer, I'll have a look & send it to you if you can give me an email address.
Feb 24, 2009 | Indesit W 123 Front Load Washer
Getting to water pump
To gain access to the pump, remove lower plastic cover at front by prising down with a screwdriver, and remove same.
You will see the pump pre-chamber cover, unscrew it anticlockwise,and check for anything in there .
Refit cover and refit plastic panel.
Please rate my fixya solution.
Thanks.
Jan 31, 2009 | Indesit W 123 Front Load Washer
Pump pre chamber lid wont open
Oct 25, 2008 | Indesit W 123 Front Load Washer
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
55 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
