Question about Dryers
Thae small belt is off and the tensioer was laying on the bottom. where does the tensioner go and how does the belt hook to it?
  • 8,197 Answers
Posted on Nov 12, 2010
Drive belt installation for zt2552a
find which pully is the drive belt tensioner
feed the belt over the other pullys leave the tensioer one till last
Jun 01, 2016 | Cars & Trucks
How to change a belt tensioner
most bvelt tensioners are bolted on with one or two bolts.use a serpentine belt tool to move the tensioer to remove the belt. remove the bolts holding down the tensioner and replace it.then move the tensioner,and if it has a set of lock holes,insert an allen key to keep it locked ,and replace the belt.once the belt is loaded properly,move the tensioner,remove the allen key and gently let it back and check that the belt is on proper.some cars require removal of a motor mount and lifting of the engine to get at the tensioner.
Mar 10, 2012 | Cars & Trucks
How do you assure proper tension on the serpentine belt after replacing the alternator?
try to turn the pulley with your hand or a wrench, if you cant turn it, its tight enough. If it has a Automatic Tensioer, then it should be OK, if the tensioner goes its full travel smoothly.
Nov 15, 2010 | Ford Explorer Cars & Trucks
Replace serpentine belt on 03 Saturn ion ? how do i release tensioner and where is it located
for the most part there is a tensioer holding the belt on give these websites a try www.alldatadiy.com and www.autozone.com wish you the best of luck Michigan Man.
Mar 08, 2010 | 2003 Saturn ION
Looking for an overview of changing power steering belt
Remove the 14mm bolt securing the alternator tensioner to the alternator. Then take the tensioner off and use a prybar to slide the alternator back enough to take off the belt. Then loosen the 14mm p/s tensioer bolt. slide the pump back and change the belt.
Installation is the reverse of removal.
Good luck.
Nov 24, 2009 | 2002 Hyundai Accent
S60. 2.4T removing and replacing timing belt
remove auxilary belt remove one bolt from timing belt cover remove cover turn engine to tdc using socket on crank nut check cam pulleys lined mark with white paint or tipex remove 4 bolts on crank pulley then centre pulley nut use impact gun prise of pulley check all marks still lined up buy or borrow universal cam sproket lock tool this is important to stop cams moving when belt of release tensioer remove belt chek water pump for leaks and wear fit new tensioner then new belt keep tight on non tension side feed over sprokets tension belt to align pointer on tensioner turn engin 2 times re check timing marks fit all parts removed
Nov 23, 2009 | 2001 Volvo S60
Tensioer pulley is cocked and out of alignment
un bolt tensioner if pully bearings bad ur build up of belt residue on pulley repair or replace either salvage yard,auto store,or dealer for replacement part
Nov 01, 2009 | 1995 Dodge Ram
How do u change the belt that turns your water pump on a 96 sedan deville northstar engine
the belt is on back of head,no hard to do.remove cover,release tension, by pulling back on tensioner.
with car off grab belt with your hand and pull,this way you can see how tensioer releases tension.
Sep 30, 2009 | 1997 Cadillac DeVille
Replace 2000 buick park ave serpentine belt
Firt - study & write down (draw) the belt path,,
and be sure about it..
Then - put a wrench on the nut in the center of the tension pully.. Move the tension pully to loosen the belt.. Pull belt off..
Repeat to put new one on..
Should be pretty easy..
Jul 09, 2009 | 2000 Buick Park Avenue
Dryers Logo
Top Dryers Experts
