Question about LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive
I bought a Lacie 2TB hardrive and as soon as i plugged it in it caused problems for my 500GB model. It now will not copy large files, will not play films that are on it and keeps crashing, i have attempted to repair it using disk utilites but it say that there is nothing wrong!! The files do not appear to be corrupted! I have alot of work on the hardrive and planned to back it up on my new one, but now im just desperate for it to be saved! Help!!
  • mrmike_andre Nov 12, 2010
    I use an I Mac OSX 5.8. I just used the Disk utilites that came with my mac, which did work before when i had a similar problem. not sure about the voltage. But i am connecting them directly into my computer using USB. The one that has broken does have it own power supply i believe, well i do not have to keep it plugged in, unlike the 2TB version. I am not sure what is wrong but the 500GB hardrive keeps emitting a highpitched noise, not sure if it is the scratch disk? but it has never done it before and does not sound good
    Brigadier General:
  • 10,406 Answers
Which "disk utilities" did you use?
Ones that check the "file-system-integrity" (that every file on the disk is listed in the table-of-contents, and that no 2 files point to the same block on the disk)?
Ones that write data to every block on the disk, and read the data back, to confirm that the disk can _correctly_ store data ?
What computer? Desktop? Laptop?
How much voltage/amperage does each USB port supply to the connected USB device?
Are you connecting the devices to a USB hub, or directly to your computer?
Do the external disk-drives each have their own power-supply?
Posted on Nov 12, 2010
I have protools7 that wont load after I installed porsche design lacie 500gb hardrive
USB 2.0 is extremely slow for the purpose of doing direct recording. External drives are best used for backup after a project is done.
Dec 27, 2014 | LaCie 500GB PORSCHE DESIGN P9220 USB30...
My Lacie Hard Drive only shows 9.99 mb capacity. and its a 2TB LaCie d2 Quadra v2.1 7200RPM U. It was just repaired by Lacie. Where's all the storage?
Please explain what you mean? When you plug in the drive it recognizes the drive but the size is showing to be extremely small?
Please let me know so I can help further.
Thanks!
EJ
Aug 05, 2011 | LaCie 2TB d2 Quadra Hard Disk v21
My Lacie 500GB External Hardrive has just started making loud clicking noises. What should I do? I'm feeling quite worried as this is my only backup system. 3011 10KU SN...
It's not a good sign if a hard disk is making loud clicking noise. It means that the hard drive is about to give up. The clicking sound you can hear is caused by the arm of the hard disk knocking against other components in the hard drive. I recommend to back up your data as soon as possible.
Good luck,
Ryan
May 24, 2011 | LaCie Computers & Internet
I have a Lacie wireless space network drive (1TB) connected directly to my router. I'm only using the switch functionality and have my pc connected to the internet through one of the 3 ports on the...
Here is what LaCie suggests about this issue:- first backup any data you have copied on Wireless Space. You can also backup your configuration: from "configuration" tab of "Support" widget, click "save" button next to "Configuration file", it will download a backup file.
- still in "configuration" tab of "Support" widget, tick the third box labeled "Restore device to factory state (data erased)", or any equivalent quote in selected language, and click apply
- the device will reboot, rebuild hard drive image, then reboot on default state. The issue is definitively fixed
- it is recommended to apply latest update downloaded from LaCie website
- you can restore previous configuration in "configuration" tab of "Support" widget, click restore and select previously downloaded backup file
Feb 07, 2011 | LaCie Wireless Space 2TB Wireless Storage...
Help is it possibol to upgrade lacie big disk extreme 500gb to 1tb or 2tb. thanks. FC
Maybe. If the current disk-drive has an IDE interface, then your 500GB disk-drive already is the largest IDE disk-drive ever produced. Or, if the current disk-drive has a SATA interface, then the sky (or the thickness of your wallet) is the limit.
Nov 15, 2010 | LaCie Big Disk Extreme 500 GB Hard Drive
I accidently formatted the drive, now have no
try recovery softwares, download pc inspector file recovery software its free on net
Sep 21, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I am having a problem copying large mkv files from a WD 2TB mybook to another WD 2TB mybook. they are both formatted to NTSC. I had no problem loading the first drive but the second one is giving me fits!
In order to fix this problem, be sure that the drive is formatted to NTSC. Mine was, however, when I started loading mp3 files to the drive first, it somehow got reformatted to FAT32. I don't know how, but it did. Copy your mkv files FIRST!
Apr 14, 2009 | Western Digital My Book Essential 1TB...
Downloading...
ok..no worries.
go to www.lacie.com and look for support downloads..then your model number and o/s..
should do le trique, n'est pais?
and you might consider backing your ext drive up with this option, too...
Mar 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie Silverscreen USB2.0 500Gb
If you can use software to encapsulate the VOB file(s) in an ISO, it will play them in order.
Feb 07, 2008 | LaCie Silverscreen 80GB USB 2.0 - Portable...
My Lacie 500GB drive shuts my laptop down when i connect it.
similar issue: my notebook hangs instead of restarting. i thought its the usb2.0 of my rather old(3yr) notebook. but i bought a cheap usb box for my old 120G hdd and it plug-n-play like a charm on the same old notebook/same usb port. quite frustrated with this Lacie 500G beast.
so i ended up backing up my notebook using the 1-click backup of Lacie but using my old 120G hdd instead of the new Lacie500G. but then, search as i would through the Lacie documentation, i see no mention of how to restore the data... still looking...
Jan 27, 2008 | LaCie Design by F. A. Porsche 160 GB Hard...
LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive Logo
153 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
