Question about Brother Office Equipment & Supplies
The mfc9440cn i have is continuly saying that the belt unit and the drum need to be changed even though they have both been changed recently. Is this a problem with the printer or the belt unit/drum?
You probably need to reset the counter on the parts life. Depending on the machine you have - you can do a parts life check - but it will always read 0 part life left, if you haven't reset the counter...
Posted on Nov 05, 2009
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. Amazon.com and some other stores have the unit for under $100. http://www.amazon.com/Brother-BU-100CL-HL-4040CN-HL-4070CDW-Series/dp/B000SC245E is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002252/mfc9440_usa_usr_b.pdf . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
HL 4040CN is printing with a pink tint, it also says drum end soon and has said that for a while. What sould I do?
I have a similar problem now: magenta stain over the entire page when printing anything with any color (even just a hyperlink); B&W text is no problem.Not the PC; even the Demo Page from the 4040 menu does this. Updated the 4040 firmware tonight to latest (1.24, etc), but no better.Recently replaced the Magenta cartridge (official Brother cartridge), though saw this problem near end-of-life of the previous Magenta cartridge. Drum Unit status is 42%, so not expected to be near end-of-life.
Nov 28, 2011 | Brother HL-4040CN Laser Printer
What is a 6 A code mean ??? on brother mfc9440cn
Error 6A is a fuser failure error. You will need to replace the fuser unit completely.
The part numbers are
For the 115volt model: LR1962001
For the 240volt model: LR1963001
Good luck
Sep 27, 2011 | Brother MFC9440cn AllInOne Laser Printer
The drum stopped turning on our Asko t700 dryer even though the dryer motor works fine so it runs and blows air but will not turn. Both of the fuses seem fine and as I say the motor and everything else is...
the belt is broken, here is a thread:
http://applianceguru.com/forum2/2043.html
here is a manual:
http://www.ajmadison.com/ajmadison/itemdocs/English-T711-721-731-761-781_UCG.pdf
Hope it helps Tim
Apr 25, 2011 | Asko T700 Electric Commercial Dryer
The drum stopped spinning on our Samsung DV218AG. Less than a year old. Suspect drum belt broke. Does the dryer have the belt in the rear or bottom? What type of belt is needed?
Welcome to FixYa.
Yes it does have a belt. I'd say your assessment is almost bang on, based on your description and my experience. I've seen this many, many times...though the belt usually doesn't break it just comes off. Very common for Samsung dryers for whatever reason.
**Unplug the unit before proceeding...safety first**...
The good news is if it's accessible from the back you can simply remove the small panel around the exhaust tube as shown here,
if it's not you'll need to go from the front...do-able just a little more involved, let me know.
Once in the back the belt should look like this when routed properly, with the "V" grooves towards the drum and motor pulley.
i.e.
Hope that moves you forward...or even better, to the finish line, lol.
Let me know what you find. If this is something you think is not within' your scope of expertise please call a pro.
I will try to help in any manner I can of course as well. Good luck.
Regards,
Macmarkus :)
Mar 28, 2011 | Samsung DV218AG Gas Dryer
There is a warning said : " fuser unit end". What is the problem for that printer HL-4040CN? Even after I changed the drum unit and belt unit, there are still 2 warnings appearing to ask for...
first you are talking about the FUSER END message that means you have to change the FUSER and as for the DRUM and BELT you have to RESET the TIMER to tell the printer that it has been changed as well as for the FUSER those are consumable parts they have a life and the printer is programed to tell you to change them after so much copies.
Jan 05, 2011 | Brother HL-4040CN Laser Printer
Getting a message saying change belt unit...what's that? is it easy to change? Replaced Drum Unit 6 months ago and I still get message Drum Unit end soon.
The instructions to reset the drum after changing are packed with the new drum, and the belt unit is the transfer belt that also wears out and needs changing periodically. The instructions are packed with that also and not hard to change.
Dec 15, 2009 | Brother HL-4040CN Laser Printer
Constant drum error on Brother MFC9440CN. Already replaced drum unit
may be the drum you are using for it is not compartable with it.
Oct 16, 2009 | Brother MFC-9440CN Laser Printer
316 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
