Question about GE Spectra JBP84 Electric Kitchen Range
GE Spectra Range JBP84D purchased 10/20/2008 as best my wife can remember she was never able to get self cleaning oven to clean. she thought that we had extended service hovever service says no. When you follow self clean procedure and then press start LOCKING light blinks but door latch does not lock and cleaning does not start. We tried shuting off power for over 12 hours then clock will blink and has to be reset, If we did it for shorter periods time did not have to be reset so we left if off overnitght, as local tech said that may reset computer chip.
  • 3 more comments
  • jth5686 Nov 12, 2010
    Every thing else works great. only does not lock door for self clean.
    Local service man would not work on it because he said everything is controlled by electronic panel in range panel He did not change me anything
    he also said that this model is a high end range, if it was a lower end model no problem replacing individual parts
  • jth5686 Nov 27, 2010
    I have been busy so did not post answer to my problem that GE technician found.
    The door switch on this model is single pol dual throw
    if door is open light comes on, if door is closed power goes to controller for convections oven and cleaning control.
    He replaced the switch but the problem was actually caused by a loose connection to rear of switch. He tested the old switch it tested good but he had to put the new switch in because if the old switch failed it would be his problem.
    If some one had suggested the door switch instead of infinate switch I would have tsaved almost $200.00 not counting cost of Fixya.com
    I have been busy so did not post answer to my problem that GE technician found. The door switch on this model is single pol dual throw if door is open light comes on, if door is closed power goes to controller for convections oven and cleaning control. He replaced the switch but the problem was actually caused by a loose connection to rear of switch. He tested the old switch it tested good but he had to put the new switch in because if the old switch failed it would be his problem. If some one had suggested the door switch instead of infinate switch I would have tsaved almost $200.00 not counting cost of Fixya.com
    Brigadier General:
  • 3,917 Answers
Thank you for contacting Fixya.com.
It looks like you may have a bad Infinite switch. It controls the complete oven for bake, broil, and self cleaning. Remove all wires from the switch terminals. Set the infinite switch on high and place your ohmmeter on the L2, H2, P and H1 terminals to check for continuity. If there is no continuity between L1 and H1 or between L2 and H2, the infinite switch is defective. If there is no continuity between P and H1, the indicator light circuit is defective. Remove the infinite switch by removing the screws or nuts that hold it in place and install a new infinite switch by following the disassembly instructions in reverse order. You will not be able to find it at lowest; you will need to order it from a supply house. You can order this part at the following locations online... WWW.APWAGNER.COM, or WWW.REPAIRCLINIC.COM, or WWW.PARTSTORE.COM. All 3 of these places are a good place to order your parts because of their liberal return policy.
Please get back to us if you have any further query.
Have a nice day.
Posted on Nov 12, 2010
  • e-Guru
    e-Guru Nov 12, 2010
    Correct. But the symptoms that you mentioned is clear indication of a bad or partly bad infinite switch.
    I have seen similar cases with other customers and had to replace the same.
    Thanks
Stuck in clean mode. Ge Spectra xl44 My wife cleaned the over a couple of years ago using the self cleaning mode and ever since then the oven has been stuck in clean mode when we try to use it. I've...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 Gas Stove & Oven: When using self cleaning oven can I put the stove cooking racks inside to clean also?,
Is this my wife asking this ? lol, i had the same arguement with her, dont leave the racks in, it will tarnish them possibly bend them,that stove gets up to 900 F
Oct 29, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Lost manual for model # jgsp31ger3wg, GE Profile gas range. want to clean oven...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 11, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE spectra xl44 stove model #jgbp28bea2ct, when I turn on the oven the clean light winks and the oven does not heat up. please help
heatman101
Aug 16, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
I have GE XL44 range. How long should i run self
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!!!
Dec 09, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I clean a GE gas range (self-cleaning oven?)
What do i clean the burners with ? the round surfers is harder to scrub, what do you advice .
Apr 20, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Don't know how to start the self cleaning oven. Please advise.
Most service techs will advise you not to use self clean features on a oven due to excessive parts failures from the extreme heat.
Feb 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I don't remember how to use the self cleaning feature
Remove everything from the inside of the oven, lock the door if your model has a latch handle that you move from left to right to lock the door, then set the oven selector switch to clean.
Dec 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP85WEB5WW Range
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Aug 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
See all GE Spectra JBP84 Electric Kitchen Range Questions
GE Spectra JBP84 Electric Kitchen Range Logo
127 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
