Question about Maytag Washing Machines
Is the maytag bravos he washing machine suppose to fill up with water over the clothes or not
  • Anonymous Mar 26, 2014
    machine doesn't fill with enough water to wash cloths
    Genius:
  • 1,028 Answers
On most front loads you may see very litle water if any water level is not adjustable
Posted on Jun 18, 2008
How much water should be in the tub during wash cycle on a maytag bravos?
That is a good question I own one and it _______. Set it to bulky and wet the cloths first. The water level determined by this machine has something to do with the weight of the cloths. You cant get cloths clean without water.. I add water from the utility sink and it remembers the water level.
Oct 15, 2014 | Maytag Washing Machines
Maytag bravos quiet series 300.. I washed a blanket and it literally disintegrated into millions of pieces. How I clean it out from the inside basket. I cleaned it out of the tub but I'm sure there are...
I would fill the tub with water,like i'm going to wash a load,but don't put in any clothes .Run the complete wash cycle and see if the water all drains out.
Jun 05, 2014 | Washing Machines
Maytag Washing machine; Bravo,not filling up with water.
what is your model number is then we can get started okay
Jan 01, 2013 | Maytag Washing Machines
Maytag bravos doesn't use enough water
see this causes and fix it.
God bless you
Water comes in very slow This is usually a water valve problem or an inlet screen blocked. 1st check your inlet screens of your water valve. Turn your house water valve off to the washer, undo the fill hoses and inside the water valve, you will see a silver screen. If the screen is filled with water deposits, clean it out and re-install into valve. Don't forget to check your fill hoses also, some hoses come with screens that also may be clogged. Your cold water valve usually clogs before the hot water valve, all that sediment settles in your hot water tank and not in the screens. If you are on a well system, your screens usually clog more often. If your screens are good, then most likely your water valve needs replacing.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag Bravo washers is staining my cloths.......any thoughts on what may be causing this?
the upper transmission seals bad its under the tub agitator and letting oil into the water called "wash back" you need to replace this seal and stains will disappear
Apr 06, 2011 | Maytag Bravos MTW6600T Top Load Washer
Water level in washer
The basket floats. The washer relies on a circulation pump to wash the clothes. THEORY OF OPERATION PAGE 22
let me know
May 08, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Washing Machines Logo
97 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
