I have a rca dlp model# HD61THW263 I recently replaced the bulb now I have a dark faded spot in middle of the screen that starts off small gets bigger. And does the wattage of the bulb matter?
  • gordonshipps Nov 12, 2010
    What is correct bulb wattage for this model tv?
    what is corredt bulb wattage for a RCA DLP model# HD61THW263
  • 4,889 Answers
Its not about the wattage of the bulb. Its about getting exactly the same replacement bulb. The question is did you replace the bulb that is exactly same as the replaced one?
Posted on Nov 12, 2010
  • 11,800 Answers
The dark spot is caused by the deformation of the lenses due to the heat of the bulb - This is a very bad news, the lenses when they get deformed they can't be repaired and replacing the entire optical engine will cost almost as much as a new tv.
Verify immediately the status of the lenses and find out what is wrong in there - check the ventilation, the bulb (yes, the power of the bulb is critical, if it's higher than what was in the tv initially no wonder that it heats the lenses) and the fitting of the entire optical assembly: bulb, DMD chip, the color wheel and the optical engine.
  • Azrael SRL Nov 12, 2010
    It's an 120 watts bulb. The original can be found here
    http://barrie.convergencerepair.com/lamp...
Dark spot in middle
A plastic prism between the lens and the lamp is melted. can't find part no. PLNS-A056WJN2
Jun 30, 2013 | Sharp XR-10X Multimedia Projector
Infocus IN24 Projector has large Dark Grey/Black Spot in the middle of the image.Lamp has 600 hours,Installed my spare "NEW" Lamp,still the same,Bulb makes no difference.Was watching a movie...
There is a lens(looks like a small magnifying glass) made out of plastic that the light shines through to focus the light on the mirror before it hits the DLP chip, that lens is Melted in the center. I unfortunately had the same thing happen to me, and I am unable to find a replacement part.
Jan 16, 2011 | InFocus Work Big IN24 DLP Projector
TV screen is dark
If the picture is dark then I suspect a bad lamp if you just replaced it...
Nov 20, 2009 | RCA Televison & Video
I have a RCA HD61LPW42 . I recently replaced the lamp but there seems to be a dull/dark spot on the TV screen where the color is always a dingy brown. when I replaced the bulb I noticed that it had...
Most likely you also have a bad Optical Block assembly. Do to the cost of the part, I would not invest the money to replace it. The Lamp failing would not cause this to happen.
I hope this helps,
Skyassoc
Oct 27, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Samsung 50'' DLP has a few dark spots on it, as well as a dark streak on the screan...what are they? I have already replaced the bulb once after two years.
It is unlikely the DLP TI chip is bad--it would just be a few small spots. There are port holes on each side of the set where you should be able to see if anything is awry--shine a flashlight in one side and look from the other. If you have replaced the lamp, then you should be familiar with the insides although how long ago that was depends on the model HLM HLN HLP HLS(my first) HLT(improvement with LED lamp, yeah) Ax50 (newer). Best luck, -Ken
Sep 22, 2009 | Samsung Televison & Video
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
Gray spots on screen on a JVC HDILA model HD 56G 787
The HD-ila sets accumulate a lot of dust in the light engine. The worst offender is the little fold mirror just under the lens. I take my set apart about every 8 months or so to clean all the dust from the light tunnel and all lenses, mirrors, diffusers etc. The picture really regains it's pop when this is done. Unless you are a skilled technician though, I would recommend against attemptimg this procedure as you need to disconnect the individual color lcds. Check with a local service center to get it properly cleaned.
Oct 16, 2008 | JVC HD-56FN97 56" Television
Rca hd61thw263 61 in. dlp
Seems a lightning strike took out my bulb
eventhough i have a surge protector.
after replacing the bulb perhaps 1 hour later a shadow began to appear at the top of the screen and progressed slowly down until only the edges are visible.
please can you help?
Sep 09, 2007 | RCA HD61THW263 61" Rear Projection HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
