Question about Microwave Ovens
WHEN rational combimasterCOMBI IS TURNED ON E12 SHOWS ON PANEL RED LIGHT NEXT TO PROBE SYMBOL FLASHES
My microwave oven from LG MG 604 W has now starting problem, when we open the door the light is on and even the display is okay we can set the timer but when we press the start button it doesn't start...
The owner's manual should tell you what that symbol means.
If for some reason you don't still have yours, you can download it here.
I would suspect a bad door switch or door switch mount.
You should see my text file on door switches for more information.
You can order LG parts from Encompass here or you can call them toll-free at 866-779-5835.
Sep 26, 2011 | Cuisinart CMW-100 Microwave Oven
When machine is first turned on it will run till bin is filled and it cuts off, but will not restart after ice is removed from the bin.This os a hoshizaki commercial ice machine
Remove front panel, look at controler,(where the blinking lights are) there should be a sticker on the back of the panel that tells you what the problem is by how the light flashes. IE- if light flashes 2 times, stps, flashes 2 times,etc, etc
Oct 08, 2010 | Microwave Ovens
I've misplaced the operating instructions for my williams sonoma remote meat thermometer. I can't get the probe unit/base to sync with the remote transmitter or to show a temp on the base unit and find a...
This is for a model ET-903WS: Turn the base unit on first. This is the unit with the larger display & buttons. Hold the power/mode button (upper left) down until you hear 3 beeps and the display lights up. Mine then displays "BEEF" and shows 160, with 3 blinking spaces. Next, plug the probe into the smaller remote unit. You should get 1 beep, the remote will display the temperature and the base will now display the same temp where the blinking spaces were. The first couple of times I tried, the base would not display. Unplug the probe, turn the base off holding down the same power/mode button and start over. I've had to do this as many as 4 times but it has worked perfectly while I wrote this!?! I really like this thermometer because I can put the meat on the grill go inside and have a drink while watching the game and then a friendly voice comes on when the internal temp is within 10 degrees of your target and says: Your food is almost done...your food is almost done." If you sleep through that, she comes back on at temp and says "Your food I'd done...your food is done". I take most meat off at the first warning and wrap it in foil. Watch the probe and it will continue to rise for about 20 mins. Enjoy.
Aug 08, 2010 | Microwave Ovens
I have a professional series frigidaire glass top stove and whenever I press the bake button or any other button like to set the clock F30 Err shows. what does that mean?
F30 Open probe connection.
Check resistance at room temperature & compare to RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
To find your nearest servicer, see Frigidaire Customer Support.
Jan 16, 2010 | Frigidaire Microwave Ovens
Have a kitchenaid superba part no. 4450786A with the probe indicator beeping for a temperature to be set. Prior to beeping started just used microwave to warm food; didn't need or use probe. What is...
Put the probe in the oven and beeping stopped. Left it in overnight and next morning took the probe out and there was no beeping. Have not heard beeping all day. Don't know why this worked but it did.
LaMason
Oct 12, 2008 | Microwave Ovens
GE microwave error - PROBE
Chances are the keypad (membrane switch) is shorting, or the control panel as an assembly may need repair.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting. It shows you how to test the keypad.
Also, we repair these for $39.95 (in most cases) for customers nationwide via mail. If yours needs a keypad, we could also give you the estimated total repair cost if you contact us with your exact model number.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 28, 2008 | Microwave Ovens
Microwave Ovens Logo
341 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
