Question about Siemens Lands Phones
My Siemens Gigaset SL565 has a problem. I tried to switch of the answering machine but nothing happened. When calling the line it's busy, although nobody is on the phone. I can't make any calls either. What has happened and what can I do now?
SOURCE: Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Posted on Jan 06, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: Siemens Gigaset 4000 No Sound
Hi Krister,
It sounds from your symptoms (no pun intended) that your handset receiver/speaker has gone bad, or if you use a headset, the circuit might have gotten ripped open from tension from the headset plug. You can try plugging in a standard 2.5 mm plug headset into it (real common headset). My guess is that you will be able to hear dialtone using a headset and use the phone, but the phone will continue not ring or make key beeps.
Its fixable, but with the Siemens models don't let anyone try to open it. To work properly it needs to snap together tight, and guaranteed they will gouge the plastic and break the more than 10 tabs that keep it held snug together, there are no screws. The skill to open them without damaging them is proper training and muscle memory, which is reserved for the people that do it daily, plus if the plastic needs replacing it will add to your costs. Nevertheless, if you want it fixed, just google "Siemens Cordless Repair" and click the first or second non sponsored link to make arrangements to get it fixed. Good Luck and let me know if I was right about the headset audio.
Posted on Jan 11, 2008
scottyfixit
  • 186 Answers
SOURCE: LIne In Use/Answer On Message
Just some Tips - Do you have any other phones or fax machine in the house? Check to make sure they are all hung up or press the off/ hang up button. If so, disconnect them until one brings back a dial tone when disconnected Also try cleaning the charger contacts with an eraser to the charger sends a signal that the phone is hung up.
Hope this helps!
Posted on Apr 27, 2008
CORDLESSGURU
  • 106 Answers
SOURCE: siemens gigaset A410 problem with some hardware
Your unit got hit by a lighting strike, but it is fixable. Go to www.cordlessrepair.com
Posted on Jul 04, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
I have a Siemens Gigaset A420 A Trio obviously three handsets.
Chargeable and non-rechargeable batteries are not interchangeable.
Aug 02, 2016 | Siemens Gigaset A420a Trio Dect Cordless...
Gigaset 8825 answers phone but does not record message
Some Gigaset phones have an option to have the answering machine play an outgoing message only without taking a message. You should check your settings and make sure you don't have yours set up this way. This could also happen if the memory for the answering machine is full so that it cannot record any more messages.
Sep 01, 2014 | Siemens Gigaset 8825 Cordless Phone
I have a gigaset 8825. I have a "distinctive ring" problem
I have the same phone system, and *think* you may be able to fix the problem by adjusting the amount of rings before answer on each unit. This assumes there is an auto answer system engaged. Hope that helps some.
Ken Lundberg
Jun 19, 2009 | Siemens Gigaset 8825 Cordless Phone
Gigaset 8825 message system won't work
guys- empty out your call log and your mailbox. This timeout and reset isssue seems related to memory- that should do it-
Chris
Mar 06, 2009 | Siemens Gigaset 8825 Cordless Phone
Siemens gigaset 2420 two line phone drops calls
dump the memory by deleting your mailbox and your call log-
Feb 15, 2009 | Siemens Gigaset 2420 Cordless Phone
You did get spiked from the power company, and your system needs repair. Go to www.cordlessrepair.com for help.
Jun 23, 2008 | Siemens Gigaset 4000 Phone
Can't activate answering machine
Here is the manual for almost the identical phone, in English: http://shc-download.siemens.com/repository/1321/132104/A31008-M1714-R301-2-6019_en_USA.pdf Pages 18-23 discuss the operation of the answering machine.
Mar 14, 2007 | Siemens Gigaset 2415 Cordless Phone
Line cut off problem
That is a common problem with this model, normally happens after a storm passes through. Unfortunately there is no easy fix for on site, it would need to be sent in for repair or replaced. You can google Siemens Cordless Repair to find service facilities.
Dec 18, 2006 | Siemens Gigaset 2420 Cordless Phone
Lands Phones Logo
302 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
