Question about Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver
Trying to open the battery and just can't get it open. Can you tell me how many screws or where they are please? We're trying to figure out what size battery we need, got two different answers. Ordered a heavy duty. But can't get it open. We found six but can't see two more. Thank you.
  • 280 Answers
The battery box for this scooter is easily taken apart to replace the batteries. Remove the battery box form the scooter and turn it upside down. There are 8 screws which hold the 2 halves of the battery box together. The screws require a long shaft Phillips #1 screwdriver to remove because they are at the bottom off long plastic round recesses in the battery box. Don't forget the 8 lock washers under the screw heads.
This scooter takes 2 batteries rated at 12 AH. The best type are AGM batteries (advanced glass mat). When you have the battery box apart, turn it right side up and pry the batteries off the velcro. Note which terminals are connected to red (+) and black (-) on each battery, The batteries and the terminals will be marked. Re-use the velcro by putting it on the new batteries to keep them secure in the box. Connect the four fast tab terminals to the batteries and push down on the batteries to get them to stick to the velcro. Turn the box over and install 8 screws making sure a lock-washer is under the screw head. Using your long screwdriver tighten securely. Plug in and test scooter and charging of the new batteries. Hope this helps.
8 screws 12 or 17 amp AGM
Posted on Nov 14, 2010
  • wcdoc1953
    wcdoc1953 Nov 14, 2010
    note: 8 screws for both models 17 amp AGM is for the plus model
Why is this so hard to figure out? I am afraid of damaging it.
if its saying open it up to reset the battery..it means open it up and to take the battery out and put it back in.
please let me know if this is what you are asking,or this is what its telling you to do.
Dec 01, 2016 | Samsung Tab Tablets & eReaders
I am having the darndest time trying to open the radian led light to get the batteries in. Can you help?
Just got it! After 20 mins spent in hurting myself with the damn plastic, I figured out was the little hole on the back was meant for: lose the screws on the back, take off the back part and the little squared plastic so that the hole is uncovered, and use one the screws to push through to hole while pushing the red button. The pocket for the batteries will eventually slip out.
Jan 29, 2011 | Bell Sports Cycling
Acer aspire battery does not recharge how to open
Are you trying to open the battery? is so then please don't it can be very harmful,
Does the system work when still plugged in? If so then the battery is bad, If it does not then there is an issue with the power port usually the solder breaks loose and is a quick repair for a technician,
However opening the laptop itself is virtually impossible to explain on here... Remove the battery sometimes there are small screws.
On the bottom of the laptop screws are usually grouped by letters or symbols.
Keep all like screws together. If there is anything we can do let us know,
Nov 08, 2010 | Acer Aspire 5043WLMi (LXADX05009) PC...
Hi, I have the cloud B sleep sheep and it appears to be malfunctioning. It turns on/off before the time limit is up. It's also making a swoosh sound like static and when I go to reset it, it takes a few...
Hi, it sounds like your Sleep Sheep may need new batteries. When the batteries begin to die, the Sleep Sheep starts to act erratically, sometimes only turning on for a second or two, or only working if you hold down one of the buttons.
To open the battery compartment, you'll need a tiny Phillips screwdriver, like one found in a computer repair toolkit or an eyeglass repair toolkit. Once you've removed the two screws, slide the battery cover to the left (away from the screw holes). The Sleep Sheep takes two AA batteries.
Hope that helps!
Oct 19, 2010 | Cloud B Sleep Sheep Plush Sound Machine
Mickey Mouse Clubhouse microphone
don't have the instruction and can't get the mickey mouse wireless microphones to work. Do they work through your stereo?
Dec 22, 2009 | Toys
Open buffalo ministation case...did you figure it out?
haven't figured it out yet then here's how.... undo the four obvious screws. The ni the mifddle at both sides there's tow 'stick out' bits from the attached to the middle sides on the bottom bit of the case. First you pull the two ends up and twist a bit and use more force than you think you should. CRACK it comes apart. Next itme, better if you do this first time, push a small screwdriver carefully against the grey liner in the mifddle at one side whilst holding open the tow end on the same side. Less of a crack and less force but more hands needed and it open. Cheers from Knobcottage
Nov 27, 2008 | Computers & Internet
I have a Bulova Caravelle mens wrist watch case number C877548. I have to replace the battery but I can't figure out how to get the back of the case off. Thanks
Hi. If you take a tiny screwdriver (one that you might use to screw a screw into an eyeglass and run it gently around the back you will feel an indentation where you can insert the tip and pop open the back. The battery is easy to access but trying to get the back back on is the problem! Good Luck.
Sep 11, 2008 | Bulova Watches
How Can I Take Apart My Samsung SCH-u740?
Go to http://lsidave.com/Popups/Samsung.html if you have not found directions yet and good luck!
Jul 26, 2008 | Samsung SCH-u740 Cellular Phone
Pride Mobility Products Go-Go Elite Traveller Scooter - 4 wheel w/12 AH Batteries & Charger + Flat Free Tires - Silver Logo
221 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
