Question about Cozy (W352E) Heater
Need a gas valve for a cozy model # DVCF653B cozy part # 78090
  • 59 Answers
Call 502-589-5380 and they will take your zip code and give you a list of dealers in your area.
Posted on Nov 24, 2010
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Need to replace a pilot *** on a cozy heater model dvcf653b
there are 3 phillips head screws on the bottom of heat exchanger and wre the burner assy. meet and 3 wing nuts on the bottom back remove and disconnect the gas line and the wires to valve and remove the assy. easy to remove thermocouple from this point install in reverse order, may need to adjust the pilot flame down on the gas valve if the pressure is causing the thermocouples are burning out.
Dec 09, 2010 | Cozy (W352E) Heater
Have a Cozy 35,000 BTUH vented closed front heater with bad gas valve. Need to remove manifold from the valve. Is the valve a right or left hand thread.
on back of unit remove the 2 screws holding down the gas valve, remove wires and pilot tubing from valve, open side access door and you will see a brass nut turn counter clockwise and remove manifold and valve out the back of unit then unscrew the valve from manifold.
Nov 11, 2010 | Cozy Enclosed Front Console Heater 20,000...
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
Installing high altitude kit on Cozy NG furnace
the orifice that comes with the unit has a starter hole only needs to be drilled out, in the instructions is a chart for altitude de-rating.
Oct 04, 2009 | Cozy Enclosed Front Console Heater 20,000...
Gas valve only opens when struck lightly
Sounds like a a bad gas valve, not serviceable - replace.
Apr 30, 2009 | Cozy (W352E) Heater
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Propane conversion for cozy model CF503C
try national energy for a conversion kit they should be able to help or the will know some one who can
Jan 10, 2009 | Cozy CFR Utility Heater
How do you hook up a millvolt thermostat to a cozy model vcr351
If the cozy is a milivolt system then on the gas valve there should be three terminals.. th/tr/thtr the thermopile(wich creates the milivolts) goes to the tr terminals.. your thermostat goes to the th....
Dec 22, 2008 | Cozy (W352E) Heater
Cozy heater
Make sure the gas valve is turned to the "On" position after the pilot stays lit. You may need to replace the thermopile. Some units have a thermopile rather than a thermocouple and it will not allow the gas valve to open if not enough voltage is being sent to the gas valve. Hopefully your gas valve is working properly and will not need to be replaced.
Dec 04, 2007 | Cozy Enclosed Front Console Heater 70,000...
Cozy (W352E) Heater Logo
137 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
