Question about Kenmore 65942 Electric Dryer
I have a kenmore dryer model 76784100 and it wont heat. I took the heating element off and one of the coils is broke, not juice going thru, can I weld that together safely?
catriver
  • 878 Answers
SOURCE: replacing the heating element Kenmore dryer 110 64892
nestor, on the posted model, you want to drop the lower front panel. Take a puddy knife and push in on the clips on each side and it will pull off. Kill the power to the dryer. On the right you will see the heater housing. The housing will have a front deflector. You can remove that deflector by removing the screw on the bottom or simply just bend it down out of the way. Remove the 2 wires on the left that attach to the element itself. On the left side of the housing there will be a quarter inch screw that holds the element in place. Use a small socket set to get it off. Now the element will pull right out of the housing. Sometimes they are difficult to pull out but it will come out. Did you ohm out that element to make sure that was the culprit? Catriver.
Posted on Dec 09, 2007
TheMobilian
  • 8220 Answers
SOURCE: kenmore dryer model #86870100 runs but no heat
this kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.8e8a912.jpg
Posted on Dec 15, 2008
SOURCE: cant find heating element for kenmore 80 series dryer
it should be in a housing mounted just inside the back panel. unlatch the housing from its mounts and the element slides out from the bottom
Posted on Jan 02, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Dryer does not heat.
DEAD DRYER
Posted on Feb 07, 2009
emissionwiz
  • 76630 Answers
SOURCE: the coil on my heating element for my kenmore
u must replace the heating element they are not repairable
Posted on Nov 25, 2009
Kenmore heavy duty plus dryer modle number 886573130 works fine just stopped heating up.
Gas dryer no heat means the heating element broke or fell apart, need to install new one, go to sears hardware and order a repacement....model # in hand.
Feb 22, 2015 | Kenmore Dryers
Our Kenmore elite dryer has no heat, what do I do?
The First thing I would do is look at the heating element, you must unplug the dryer and remove the screwsfrom the back of the dryer and then locate the element and inspect it for being broke, if any of the coil of the element is broken you must order a new element.
Jul 18, 2011 | Kenmore Elite HE4 Electric Dryer
Hi my dryer is only just over 1 year old so of course warrenty is up and it wont heat. it runs and circulates but no heat, my husband cleaned out the vent tube what else can we do?? it cant be major its...
it could be the heating element even though it is just over a year old, i have seen heating elements go out on 3 month old dryers, it also could be a thermostat the best thing to do is make sure it is getting the full 220 volts going to it, if it only has 110 volts the motor will run and have no heat and vise versa, then if that is good get to the heating element and look it over real good most of the time the heating coil will be broke into it wont look burnt just broke
May 04, 2011 | Amana Dryers
I have a Kenmore 80 series gas dryer that will not heat up anymore. I took off the small clip in front and can see the heating element start but no flame or heat . Also the dryer will make an intermittent...
check the thermal fuse on the blower housing,if it shows good then possibly the gas valves are weak on the burner tube and wont let gas into the burner
Nov 18, 2010 | Kenmore Dryers
How do i access heating element to kenmore electric dryer
send a model # to appliancesplus.net
the step ya thru it
Apr 28, 2010 | Kenmore 63942 Dryer
Dryer wont heat
could be the heating element cant check with meter have to open her up and see if one of the heat coils is bad a new one will cost around 80$
Jan 14, 2010 | Kenmore 73952 Gas Dryer
My electric dryer wont heat took off the coil part
There are 2 things in series with the heating element.
One is on the element housing. One sets the amount of heat and the other blows out if it gets to hot from things that block the air flow.
Nov 03, 2009 | Dryers
Heats then stops
You need to replace the 2 solenoid coils on the burner valve . When one of them gets hot from electricity going thru it , it opens ( shorts internally ) . After the dryer cools down , they will work again until they warm up , then , no heat . Take your complete model number , when you get the parts .
Sep 22, 2009 | Whirlpool LGR3624JQ Gas Dryer
Kenmore dryer 90 series model 66901692
heating element is located at the back of the dryer. if you can see a big coil of wires like a long spring laid back and fort to a duct , that is the heating element.
Feb 19, 2008 | Kenmore 62602 Electric Dryer
Kenmore 65942 Electric Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
