Question about Matsonic MS8147C+ (N82E16813184008) Motherboard
Support IDE HDD how many GB - Matsonic MS8147C+ (N82E16813184008) Motherboard
I use 40gb ok....
Posted on Jun 19, 2011
Dear i am using ms-7142 v-1 motherboard. now i,m using ide 80 gb hdd.now i want to connect 160 gb sata hdd.its not showing bios also.hdd is working fine.i reinstalled os.and installed sata raid driver
first thing I would try is seeing if the sata drive is recognised on another motherboard if at all possible ,in order to eliminate the motherboard as the issue.If it is recognised on a different motherboard it is more than likeley a bad cable or a bad board .
Sep 23, 2014 | Computers & Internet
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Seagate pipeline hdd 500 gb. can I remove it from a lorex dvr, and put it in my pc?
Any drive will work - but you have to make sure that its physical configuration matches your pc and that you reformat the drive since the format used for dvr use is not compatible .
Sep 21, 2017 | Seagate Barracuda 7200.10 ST3250310AS SATA...
Toshiba hdd2171 has failed (no boot, very bad sounds coming from hard drive) any ideas what I can replace it with? Appears to be 2.5 inch, IDE 40gb, can i replace it with another toshiba ide hard drive,...
Yes, you can replace it with another Toshiba hdd 80GB or 120 GB. It doesn't have to be a Toshiba HDD. It can be any HDD that has an IDE interface for the ribbon cable to plug into. I prefer Western Digital hard drives myself, but Toshiba does make very good hard drives as well. There are several name brand HDDs out there. Just make sure you go with a name that you trust, I don't suggest going with some off-the-wall brand for a HDD. I've tried some "No Name" HDDs before and they have all failed within a 1-2 year period. You don't want to take the risk of an HDD crash and losing your data again within the next year.
Apr 12, 2010 | Toshiba (HDD2171) 40 GB Hard Drive
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
Aug 11, 2009 | Intel D845GVSR Motherboard
2nd ide hdd not detected by os
Have a look for the drive in "Device Manager" (control panel -> system -> hardware tab) and see if it is there.
If it is, go to the "volumes" tab and press the "populate" button.
Sep 29, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Trouble in HDD
I dont think its supposed to copy data in a boot process
copying and booting are totally different processes
Did you mean to say you have hdd issues
Feb 28, 2008 | Seagate (ST380011A) 80 GB IDE Hard Drive
Matsonic MS8147C+ (N82E16813184008) Motherboard Logo
Top Matsonic Computers & Internet Experts
David
David
Robert Karst
Robert Karst
TheJustin
Are you a Matsonic Computer and Internet Expert? Answer questions, earn points and help others
