Question about Dishwashers
I have a triton xl model @ gsd6200g00bb serial #va790400b. The dishes on the top rack are not getting clean. I have removed the top, and middle, and bottom arms cleaned calcium out of them. Removed the screen below the lower arm cleaned. The top and middle arms are still not spinning during wash cycles. Where do I go next?
  • Dishwashers Master
  • 3,247 Answers
Apart from the spray arms themselves there could be other reasons why the water is not getting up to the middle and top arms.
The distribution circuit from the wash pump that feeds the arms could be blocked or the wash pump itself is not developing enough pressure to push the water up. I am assuming the dishwasher is taking in water at the start of the cycle and you can see water at the base.
The distribution circuit to the middle and upper arms can be viewed in this diagram.
The part 585 carries the water up from the wash pump circuit
The wash pump circuit s shown in this diagram.
The pump is part 310 and the water is distributed to the upper arms by part 450.
Your dishwasher has got a turbidity sensor which checks if the wash water is dirty. If so, it drains the water out during wash cycle and lets fresh water in. A reason for not enough water circulating in upper arms could be the drain is happening faster than the inlet water is getting in which can cause a nett drop in water circulating in the dishwasher. Question - do you hear drain pump running when the wash is also happening?
Hope we can solve the root cause of the problem.
Posted on Nov 12, 2010
Top dish rack dishes don't get clean model 8575637
Most dishwashers have a rotating spray bar underneath the upper rack. Over time bits of food can clog up the holes and then dishes won't get clean in the upper rack. Check to make sure all the holes in the spray bar are clear and that it is rotating freely.
Mar 22, 2017 | Dishwashers
I have a KitchenAid Dishwasher Model KUDT03FTSS0. I am having a problem with the glasses on the top rack not being fully cleaned. There seems to be an amount of residue left on the glasses. I have...
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Jun 25, 2011 | KitchenAid Dishwashers
We have run the dishwasher through several cycles, there is no water whatso ever getting to the top rack of dishes , the bottom rack is pretty clean but the top is dry like it has no water at all
Try unscrewing the top and middle arms and soaking them in vinegar or CLR to remove any calcification that could be blocking the spray holes. If that does not work there is a blockage somewhere between the middle and top water feed. and the entire casing needs to be taken apart to verify where it is.
Mar 15, 2011 | Dishwashers
My GE Triton XL dishwasher (6-7 years old) doesn't seem to be spraying water. Is this a fixable issue or is it time to replace it?
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 06, 2010 | Dishwashers
My GE Triton XLdishwasher, model GSD6300 Gooww is leaving a
The problem is hard water. www.dishwasherfilter.com has a great new product out that will solve this problem once and for all. It filters the water entering your dishwasher and leaves your dishes looking amazing. They even have a money guarantee if you are not completely satisfied. Check it out. You will love it.
May 15, 2010 | GE Tritonr XL GSD6260JCC Dishwasher
My ge triton xl dishwasher isn't getting are dishes clean. There is a white film on the glasses and I find dark spots on my plates. There is always dish soap left behind in the dish soap container. It was...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 10, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Makes a funny noise
I had the same problem with my Triton XL Model # - GSD6660G02SS Dishwasher. I tried adding water, zip tied each wash arm (one at a time) and had no positive result. Then I noticed a notch on what is called the docking cone. It supplies water to the middle wash arm. When the upper rack is pulled out you can see the cone at the back of the washer. Anyway I put a rubber O ring on this notch and the noise stopped. I can't tell from the parts list if the O ring is supposed to be there or not. Maybe a GE repair tech can confirm this. Hope it works for you as it did for me.
-Mark
Jan 02, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
Dishes not cleaning
it may be hard water or some other minerals in your water. there is a new product out called the dishwasher filtration system and it actually filters the water going into the dishwasher. i tried everything to get my dishes clean but nothing worked until i tried this system. my glasses all had a white, cloudy look to them and it was terrible. you can get it at www.dishwasherfilter.com. it is very affordable and works amazing. the filter fits right under the sink and solves the problem immediately. if you use the discount code DFMTEN you will get 10% off
Apr 01, 2008 | Dishwashers
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
