Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
Water won't stop filling
The water won't stop filling on our Kenmore Washer 4472. any advise
  • 1 more comment
  • journeyman7 Jul 04, 2008
    kenmore 2.1 cu. ft compact top loader washer will not stop filling! im a sears tech, change computer board because that was main problem( 1out of 2 )changed board which is just below the the overlay panel with the light display only. pressure switch is well in tack as far as wireing. and the air hose is well connected to tub & pressure switch. what could be the problem? should I the tech have changed all the electronic boards or is the pressure hose & switch deffective! because they seem to be good . could u please send me the techincian test cycle for this model Kenmore 2.1 compact portable top loader
  • JJ9565 Aug 13, 2008
    Hi, my kenmore 2.1 cu. ft compact top loader washer will not stop filling! I open the top inside panel and noticed the round tube (goes down to the basket on outside) is loose from the panel. I am not sure if the loose tube causes problem....
  • Anonymous Mar 04, 2009
    where is the tube and pressure switch located
  • 550 Answers
Kenmore pressure switches are generally adjustable, the spring inside stretches over time, there is an adjustment screw or nut, clockwise raise, anticlockwise lower, water level.
  • test of the pressure switch outside of operation is difficult and indecisive,
  • switch will still throw when you blow in it,
  • a foot of water height difference is only 0.4psi so a fractional misadjustment of the switch out of the box, or the internal spring stretching just a little, and the water runs over.
Not a solution sorry, something to check for
Posted on Aug 10, 2008
  • AlmostBob
    AlmostBob Sep 01, 2008
    for jj9565
    yes that is most likely the problem, (100% likely), when you reinstall the hose add a twist tie to keep it in place, the hose works loose with vibrations and movement of the drum during operation
Kenmore won't fill with water
Make sure your water valves are turned on. Check for blockages in the rubber hose and especially where the water enters the washer. Sometimes the chack valve of a washer can collase and restrict the flow of water entering the washer. It is usually located just beyond where the hose connects to the washer. Metal screens can clog and stop water flow. Check and replace as necessary.
The electronics of the washer may also not be advancing to the point where it allows water to enter, The main dial may be faulty. Check and verify all washer settings also
Aug 04, 2012 | Kenmore 4.5 cu. ft. High-Efficiency...
I have a Kenmore washer model 110.98762792 and im having a problem with the cold water. When the water temperature switch is set to the cold/cold position the washer does not fill with cold water. W
Since U get warm water that tells you that the cold and hot water solenoids are both operating. Ergo the anomaly has to be with the device that controls temperature.
Apr 10, 2017 | Kenmore Washing Machines
My washer won't fill with water
Check the water inlet valve,kinked water lines,or clogged inlet screens.Is the lid switch working?
Dec 29, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Won't stop filling up. Water continues to flow without stopping for cycles
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Aug 28, 2011 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 90 series continue to fill w/water. Load size won't stop the fill... had to shut off water source. won't get to agitate phase... just want to stay at fill stage... can drain, spin,...
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
Aug 20, 2011 | Washing Machines
Hi I have a problem with my Kenmore washing machine,in particular I can not use hot water anymore. When I use my washing machine hot water does not stop at set water filling level (law, medium,high)...
Please post the model number for your washer. It sounds like your hot water valve has failed and is not closing. Unplug your washer's power cord and turn the hot water spigot that comes out of the wall on. If you still get water filling your washing machine, it's definitely the washer's valve and you will need to install a new set (hot and cold valves are both part of the same assembly).
Mar 11, 2011 | Kenmore Washing Machines
My kenmore 22442100 top load washer will not stop filling I have to watch it and manually stop water and advance timer past fill cycle please help advise.
your load select switch, has a hose connected to it, it goes to the bottom of tub. This tells water to shut off when it reaches desired water level for load size you selected. This hose gets clogged with soap, you have to open area where switch is, take hose off of switch and blow it out. This should solve your problem. If it does not, then load selector switch should be replaced. I am going with first solution, more common. Thanks
Sep 27, 2010 | Kenmore 22422 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
