Question about Linksys Wireless-G WRT54GS Router (e125894)
Changing com port numbers??
Hi guys. have program cmap, living aboard boat. Purchased gps reciever and can get it running in com port 9 and 10,, tried to configure cmap to run with the gps but it wont recognise the ports the gps is running out of. is there any way to change com port numbers so they can run together.. signed very frustrated
  • 147 Answers
Some (older or less sophisticated) software expects a com port with a number no higher than 4.
If this is the case, try changing the GPS emulated / virtual com port in "windows | control panel | system | ports" to something less than 5.
Posted on Sep 16, 2008
What type of boat is considered a yacht?
A Yacht is any propelled boat that exceeds 32 feet in length, and weighs less than 300 gross tons.
Jan 14, 2013 | Boating
Will not recieve sattilite signal
Hi dcross93,
Correcting GPS Satellite Reception Problems for some Receivers
There is a way to "persuade" many GPS units to use a specified communications port and baud rate for receiving the satellite signals. You need to have a little programming knowledge to do this. This may not be the problem with your unit, but it works on some receivers.
I cannot tell you all the exact procedures for doing so for each individual GPS receiver, but you may be able to do it yourself if you are bold enough, or have a friend who is experienced in basic programming. Make sure you backup and rename any files being modified, as improper code might put your unit to sleep...maybe forever.
All GPS receivers have a "setup" or "configuration" or "sys" file in the unit's main memory software that tells it how to startup and load all the various configurations...just like a Windows PC.
In one of the files will probably be a few lines of code as follows:
Your unit may have something similar to the above code. Find out what your communications Port is, and the Baud rate the modem is running, and that should force the GPS to run on those defaults. Some units will run ok on "auto" setting for the port. If you're game, it's worth a try.
One other little tidbit of programming info:
Something that has always annoyed me is the really slow simulation speed when you're trying to run through your route. Some units will allow a faster than 1X (real time) speed drive-through. Real time is sooooo slow. Look at this code:
Now look at this:
Which one would you rather put up with? The above information may not be feasible for everyone, but it's worth attempting if you want to try. Just be aware that it may VOID your warranty, if you're within that period.
These are just some suggestions to try. Maybe you can use them. If you do try, let me know how it works ou. Thanks.
Regards, Bill
Sep 19, 2010 | Tomtom ONE XL GPS
Useability question
If you are looking for an aviation GPS, Garmin DOES make units for aviation use. Go to, then click "Products" and then"In the air." They have different models, depending on your preference.
Jul 27, 2010 | Garmin nuvi 200W GPS Receiver
Dell Inspiration 1545 - Webcam wont work on live messenger
go to search for their toll free numbers.. call their tech support.. they will solve your problem for free.
Jul 10, 2009 | Dell Inspiron 1545 Notebook
2 navlinks with the same problem
Hey Guys
Found a patch that fixes this issue
Applied it to both my Navlinks and both are working fine now
Attached is the link
hope this helps anyone else
Jun 20, 2009 | GPS
The Box Super, Digital Reciever
try this it worked for me north west. 00-OB-F2-52-4E-1B-86-90 GOOD LUCK
Feb 19, 2009 | StarView SV211K 2-port KVM...
Spark Plugs....
just interseted in what sort of plugs fellow members run in their T's read somewhere that the best improvement one member made was to change his plugs to Iridium ??? (and that is excellent spelling of the word too!) Hey W-dog welcome aboard. No answer here for the sparkplugs....but Where are you in NZ? I spent some time there in the early 90's, lived in Takapuna and Christchurch. Did the Milford trek my last week there, then split, beautiful country you've got ,,,
Nov 10, 2008 | 2005 Aprilia Tuono 125
Router problem
hi sir,
check your wireless router brand/model and try to take note of it. you should visit, go to GUIDES then Port Forwarding Guides by Router, browse the brand and model of your router then select your application you want to run(ex. Texas Poker). It has the step by step guide how to porward port 9339.
If not in there, try to do this manually by accessing your router's web configurator, (ex. in internet explorer address bar). Go to portforwarding menu...just add an HTTP with named Texas Poker, also enter port number 9339 for it's port assignment.
Sep 04, 2008 | Linksys Wireless-G Broadband Router
Usb port trouble
You may have to run the program with administratve rights. (I had some trouble after getting a new laptop with Vista, that fixed it).
It may also be a faulty port on your gps, or a breakage in the usb cable... Or it may be broken...
Dec 15, 2007 | Garmin eTrex GPS Receiver
Bluetooth gps rx3715
I believe that your GPS receiver is blutooth enabled. I believe the output COM Port for the RX3715 is com port 6 and follow the advice in the following address. It should be the same or similar but this represents a different model and the com port they refer to is com port 8 for ipaq 3970.
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Linksys Wireless-G WRT54GS Router (e125894) Logo
67 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
