Sir/madam my lapi model no.extensa 4620z when i switch the on button immediatly after pressing the on/off button a sound continuously occur till the windows get start and then after inserting battery in my lapi it doesnt charge battery and and which is ocurring at time of starting it continuous to oocur and also screen light of my lapi blinks continuously and very fast battery doesnt charge when it is in laptop
tipstir
  • 67 Answers
SOURCE: Viking Dishwasher won't start. All the lights continue blinking and it sounds as if a motor is continually running.
What had changed since you last use it? Prior day? Also when last did you clean out the filters for it?
1. Drain Pump
2. Block Drain (blocked or kinked)
3. Valve Leakage
The electronic display has detected a sensor fault on the unit for the flashing you see. Check the filters and drain pump. Make sure nothing is clog also the line where the hot water goes to it. I know you said you have it under protection for 5 years and that's up right so some parts might need to be replace. If you go down to your main breaker for the unit you can trip it off and on and see if that clears it up but I you might have a serious problem with it.
Now you got 2 options.
1. Call up Viking and get an estimate of how much it will cost to repair the damage.
2. If the cost is greater than buying a brand new one then, better off getting another one then. If not then get it repaired.
Posted on Jul 31, 2008
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
SOURCE: Acer Extensa 4620Z Crystal Eye Webcam Driver
Acer Extensa 4620Z how can i install my crystal eye webcamera
Posted on Nov 02, 2008
asish_shrm
  • 121 Answers
SOURCE: battery and or charger
Hi you have mentioned
"Sometimes if I jiggle the AC adapter connection to the laptop when the battery icon starts flashing I can get it to continue working."
Looks like you have a lose jack on your notebook or the adapter itself....try to shake the connections when fitted to the notebook and check weather its the adapter or the note book jack....
If you dont have experience opening your notebook and soldering or soldering your adaptor end i suggest you take it to repair center
keep me posted
Cheers!
Posted on Nov 14, 2008
SOURCE: Acer aspire 7100 continually beeps while starting up
I had the same problem, I went to the keyboard and shut down the beep there is a check mark next to it and take the check mark off, the beep will stop
Posted on Nov 18, 2008
Acer extensa 4620z whe i shutdown laptop it's shutdown but the screen power still remains on untill i hold the power button to off , please help me
It seems that your computer needs to have a reinstall of your original setup, because the driver that tells it to shut down is not cooperating. Hopefully you have your original dvd/cd.
Nov 20, 2012 | Acer Extensa 4620 Notebook
Show me where the power button is
http://www.insidemylaptop.com/replace-broken-display-hinge-in-acer-extensa-4620z-laptop/
Scroll down to the photo under Step 1.
On the cover that is being lifted in the air, look at the button at the bottom/right.
Circle that is open at the top, with a line coming through the opening, halfway.
Power On button.
Doesn't work? Perhaps you have a bad Power On switch.
(Located under the Power On plastic button)
For additional questions post in a Comment.
Regards,
joecoolvette
Jan 29, 2012 | Acer Extensa 4620 Notebook
Speakers have stopped working and no sound is there Acer Extensa 4620Z
Check you have Windows Audio service is running or not or else you have muted the volume with mutimedia button available on the Notebook.
In your RUN Prompt, type "services.msc", press "Enter" key.
Scroll down till you reach "Windows Audio" check the "Status" is "statred" and the "Startup type is "Automatic". if not double click and change the startup type to "automatic" and click the start button to start the service.
Check the Sound button in your notebook.if you have muted. Sound can be muted from the computer control panel too.
Go to Control panel---->Click sound and in "Playback tab,Click Properties, in "Devices usuage", Select "Use this Device (enable).Click "OK" twice.
That's it.
Note : If Audio driver is missing the above step will not work.Install the Audio driver if the Audio driver is missing in the Device Manager.
That's it.
Feb 27, 2010 | Acer Extensa 4620 Notebook
Acer extensa 4620z ... enable wifi card permanantly
The switch simply turns the radio on and off, if it can stay in the on position just leave it in the on position. It should stay enabled if the radio is "on". There really is no reason to keep rurning the radio on and off. If you need to disable it, then just go to the device manager and disable it there. The switch is a pain to replace, first you have to find the right one, then the soldering of the switch is another battlle all to itself.
Oct 08, 2009 | Acer Extensa 4620 Notebook
Acer extensa 4620z Microphone Problem
http://global-download.acer.com/GDFiles%5CDriver/Audio/Audio_Realtek_6.0.1.5543_Vistax86.zip?acerid=633639019537281564 - donload the audio drivers and install them
If helped rate fixya
May 03, 2009 | Acer Extensa 4620-4648 Notebook
Oct 27, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
