Question about Canon iRC3100 Printer
Canon iR 3100 Problem Error Code E 20081 - Canon iRC3100 Printer
  • 3 Answers
HELOW SIR UR PROBLAM E 20081 IT IS A RONG CODE?SO U WILL WRITE THE CURRECT CODE SUPPOSE EXAMPLE E021-0001
Posted on Dec 04, 2010
Canon ir 3100 error code e000070-0001
the error code appears when a tension arm (front or rear) of the ITB tension roller is broken.check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
May 03, 2011 | Canon iRC3100 Printer
the error code appeared because a tension arm (front or rear) of the ITB tension roller was broken. check the tension arms (front and rear) for breakage. If either of the arms is broken, replace it with a new one.
Error e -070 in canon ir -3100 color copier
Its an error with the senor for the transferring belt. Try going into the additional functions-adjustments/ cleaning-gradation adjust- full adjustment. And follow the prompts on the screen. If this doesn't work and you feel comfortable trying you can clean the sensor. Remove the front covers, waste bottle and the drum. The sensor is located inside the chassy where the drum was at, in the middle (front to rear) on the left Do not use a vacuum on the sensor it can be damaged easily. After cleaning and reassmbling retry the gradation adjustment.
Jun 03, 2010 | Canon imageRUNNER C3200 Copier
IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Feb 16, 2010 | Canon iRC3100 Printer
Generic problem for all Copiers Canon IR 3100 error code (E000020-0081)
hello,this is caused because the patch the machine puts on the drum unit is out of range when it reads it.I replace the drum unit when i get this code and go by the directions in the box to clear the drum count
Nov 05, 2009 | Canon Office Equipment & Supplies
Ir3100 : E00070-003 error code
canon ir 3100 error code E00070-003
Oct 23, 2009 | Canon imageRUNNER C3200 Copier
I have an e 000012-0002 error on my ir 3100 - can you help please?
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
Oct 02, 2009 | Canon imageRUNNER C3200 Copier
Canon copier ir 3100 cn error code E000602 - 0202
the hard drive containing the software that drives the machine has an error. Corrective steps would be to contact to a Canon technician, who can first try to re-install the software, and if this doesn't work the hard drive has probably crashed, meaning that the drive will need to be replaced and the software re-installed
Jan 23, 2009 | Office Equipment & Supplies
Canon ir 3100 cn error code e000020-0081
HP Photosmart C 310series-driver Vindows Vista
Aug 09, 2008 | Canon imageRUNNER C3200 Copier
error code E00020-0081 my canon printer IRC3170i.what is the problem?Anybody can help?
Feb 19, 2008 | Office Equipment & Supplies
Canon iRC3100 Printer Logo
247 people viewed this question
old marine
old marine
