Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Bis. steam cleaner i have only makes a noise when turned on but brushes don't turn or **** up anything, is it a belt or pump problem? I live in Suffolk county, NY. Thank you, Vito B>
  • 48 Answers
SOURCE: how to replace pump for 7901 bissell pro heat steam cleaner
unplug unit first
take six screws out of housing.
lift of housing.
you can see pump at front of machine.
four screws hold pump in.
make sure all tubes are routed correctly.replace housing,
make sure no tubes are trapped
Posted on Nov 13, 2007
  • 48 Answers
SOURCE: Dirtlifter Powerbrush does not turn
Make the machine safe from the power source first
When you remove the belt access door you are looking at the pump belt,
To gain access to the brush belt you must turn the machine over and remove the brush at the bottom of the machine.
there are two screw in the red retainers at each side of the brush, remove the screws and the retainers and the pivot arms ,you should see the brush belt and the pump
Posted on Nov 18, 2007
SOURCE: Bissell proheat 1698 cleaner not spraying water
MY CARPET CLEANER WAS NOT SPRAYING ANY WATER OR CLEANING SOLUTION. I TOOK THE BACK OFF OF THE HEATER THAT IS IN THE HANDLE. IT WAS CLOGGED WITH CALCIUM DEPOSITS. I CLEANED THE HEATER AND PUT IT BACK TOGETHER AND IT WORKS GREAT. KEN
Posted on Jul 14, 2008
  • 37 Answers
SOURCE: HOW DO I CHANGE THE BELTS ON A BISSELL STEAM CLEANER
on your housing you will see a plastic cover adout 4 inches long remove this piece and you should see where your pump belt goes. flip your steamer over and remove the little red retainer that sits by the belt you have located. at this point you can take your brushroll out and slip the pump belt over the pump and onto your motor. then reassemble.
Posted on Sep 27, 2008
SOURCE: Bissell steam carpet cleaner
http://www.howtomendit.com/answers.php?id=76173
Posted on Sep 28, 2008
No steam comming out of my h2o x5 cleaner
see the causes and proceed with common sense. and fix it. God bless you
If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on a steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly
  • Sep 22, 2012 | H2o TR220002 Steam Cleaner
    I have the SAMSUNG WA80V3 washing machine and I have tried many detergents but they all clogg. I also put a filter but still the problem remains. Is it the water quality? I live in Oman.
    see the causes and fix it. God bless you
    stopped spraying. If the spray function has quit working on the carpet cleaner, check to make sure there is a full tank of water. If the water level is adequate, check the position of the gasket on the bottom of the water tank assembly. The gasket can become lodged, damaged, or removed. If this has happened, fix the gasket to the proper position according to the user manual, or replace the damaged or missing gasket.
  • 2 Change the belt on steam cleaner that has inoperable brushes. From time to time, belts on carpet steam cleaners become worn, and you must replace them. If the brushes on your unit have stop moving or do not turn on, you may have a damaged belt.
    Replace a belt at home easily with little expense. Refer to your user's manual for replacement instructions and the part number for purchasing the belt. Remove and replace the belt according to the model of steam cleaner you own. Purchase a new belt at home improvement stores or directly from
  • Sep 22, 2012 | Samsung CASE-DETERGENT;WA80V3 -...
    Eco steam mop no steam
    see this causes and use the common sense. God bless you
    nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
    Sep 19, 2012 | Vacuums
    On hoover steam carpet cleaner, the brushes do not rotate on low or high settings.
    Follow these steps if the Brushes Fail to Spin
    •If the brushes on your Hoover carpet cleaner fail to spin, there may be a problem---some sort of blockage---with the suction or with the belt that turns the brushes.
    Turn the Hoover carpet cleaner over, and inspect the brush area. Debris, strings, or pet hair may be tangled in the rollers, keeping them from turning. Use a pair of scissors to cut away any obstructions in this area. Flip the Hoover carpet cleaner back over, and turn it on to see if cleaning the rollers has solved the problem.
    To check the belt, turn the Hoover carpet cleaner over, and remove the bottom plate screw with a Phillips head screwdriver. Investigate the belt area to see if it is broken or has somehow slipped off. If it is broken, you can order a part from Hoover.com or from many of the other online parts stores.
    When the belt arrives, simply slide it on in place of the broken belt, reattach the bottom plate and turn the Hoover carpet cleaner right-side up. Turn it on to test your solution.
    Sep 03, 2010 | Hoover SteamVac F5914-900 SpinScrub...
    Broken belt how to fix i have a belt
    Take off belt cover on the left side of the top cover, turn cleaner over, take out screw from red lock and remove, pull cap and brush roll out, unhook the cogged belt, then you can replace the pump belt thru that opening. Put belt over the pump pulley and stretched to go over the motor shaft. Then check the cogged belt and the cogged end of the pully to make sure that there are cogs, replace belt if there are cogss missing or belt is broke, if no cogs on the pulley, then you will have to replace the pump. Pulley only comes witht he pump.
    Jul 29, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
    http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=761326
    Generic problem for all Vacuums
    Posted by buster_lls on Jul 09, 2008
    I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
    http://www.hoover.com Telephone
    Contact our Customer Service Department at 1.330.499.9499
    Monday through Friday
    8 a.m. - 7 p.m. EST
    Thanks, Don the Vac Man
    Go Ahead. Use Us.
    Jul 09, 2008 | Vacuums
    How to check the location of the pump belt?
    Jun 30, 2008 | Bissell 1699 ProHeat Clear View Upright...
    The brushes will not turn. How do I open the unit to put the belt back on?
    Hoover doesn't use belts on their steam cleaners. Either the shaft that is on top of the brush block broke off, or the turbine is bad. The turbine is what turns the brushs.
    Jun 12, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
    Steam vac hoover F7458900
    There is no belt, the brush block is turned by a turbine. Check the brush block, make sure that the shaft that goes into the turbine isn't broke off, If ok, then replace the turbine, or take it apart and clean it out.
    Jun 08, 2008 | Vacuums
    Bissell Proheat Clearview - Belt and pump keep melting
    Is the brush roll turning freely? Is there something binding the pump pulley or belt casuing it to not turn? Was the replacement pump a new one? If you replace these parts again, after doing so, try turning the pump pulley by hand to see if it will turn the brush roll easlly, if it doesn't then there is a problem.
    Apr 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
    134 people viewed this question
    Top Bissell Vacuums Experts
    Jim Thurston
    Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
