Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Hi! We have a really old williamson thermostat (not sure about the model but it says t87fi89i 2 8047 [dont know if it's i or 1 either]). We want to replace it with a honeywell t87n east-to-see thermostat. There are 3 wires coming out of the wall (red, white, green) but the red is not connected to the old thermostat. How should we go about it?
    Genius:
  • 1,015 Answers
On most applications for heating the red and white wires are used,however I would check what wires are connected to terminals on old thermostat. These connectons should be labled with initial of wire color,such as R,W,G,Y or Rc. If your green wire is hooked to R or whatever just hook new thermostat up like the old one and you should be ok. Hope this helps. Thanks.
Posted on Nov 12, 2010
How do I remove old thermostat
It really depends on the car but most cars have a thermostat housing which usually has a hose hooked to it and has two bolts make sure you get the old gasket off before putting on the new one as it will leak for more information reply with year make and model
Jan 24, 2015 | Cars & Trucks
I was wondering about the position of my thermostat on a 2000 buick park ave, and the size of the bolts thats holding my thermostat housing together? I recently had someone take it out because it wasnt...
3.8 liter?
The thermostat will be installed with the spring part going into the engine. It really doesn't matter how the thermostat sits in the opening unless you have a thermostat that sits horizontal instead of veriticle. If this was the case the thermostat would likely have a small opening or hole in it which would sit at the 12 o'clock position. This hole will help bleed the air out of the engine once you start to refill it with coolant.
The bolts heads are usually a 10mm or 13mm.
Hope that helps. If you have any more questions I'll be happy to help.
Oct 07, 2011 | 2000 Buick Park Avenue
If i give power to furnace,will thermostat work it in a power outage ? The system is 40yrs. old . the thermostat is a round dial type. Williamson : Temp-o-matic furnace and...
it should. the transformer,110v to 24v should be part of a 40 yo furnace. if not just find that tranformer and add power to it also
Mar 18, 2011 | Heating & Cooling
Hiiiii..... I have samsung Thermostat AC, But i dont know how to use the warmer / heater for the same. I dont know about the model number but its one of the old AC written thermostat. Now help me out how...
Symbolsin remote: To get proper cold air set temp 23 degree and mode"cool". To get heat set temp 30 degree and mode in "Heat"
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
Jan 03, 2011 | Samsung AW1203B Air Conditioner
My burner dont work. what can i do to fix the problem
1.Make sure you have the software installed correctly (Try Nero, Roxy, LG Burner)
2.If you do, then choose the right options depending what you want to burn (data, music, file, iso)
3.How old is your Burner? If it's really old, Then probably you need to buy a new one.
4. Try www.newegg.com / this website have really affordable DVD-RW sometimes as low as $15.99
Thanks
DiegoTech
Nov 13, 2010 | IBM NetVista PC Desktop
Rewiring the trigger on a 7 1/4 magnesium
really not that important on a small motor, but you can match colors of wires and you will be ok
Jan 20, 2010 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Need to replace an old garage door remote
will not offer support on this old, unsafe unit. sorry. replace it for $160
Dec 13, 2008 | Sears Craftsman LiftMaster Chamberlain...
Whirlpoool dryer not heating replaced the thermostat
Dont know the model number you have, but most of your items are located in the back of the unit. You need to make sure you replaced the thermostat, and not just the thermal fuse. The thermal fuse sits on top of the element shield, the thermostat is lower, down where the wires go into the element. You may have changed the thermal fuse, but the thermostat may be out. You will need to check (with an ohm meter) all the componants to find the trouble. If that thermal cut-off has went bad again, change the thermostat with it. Be sure you have very good ventilation all the way through, bad vents will cause problems like this all the time. Let me know if you need parts info. Let me know a model number as well.
Nov 16, 2008 | Dryers
Heating & Cooling Logo
246 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
