Question about Fagor 28 in. VFA-70S Electric Cooktop
I have a Fagor hob top with 4 rings. The two on the left have stopped working. The two on the right are fine. Any ideas?
5 Suggested Answers
SOURCE: Electric ring stopped working on my T1250 Cooker Hob.
MY PHONES RINGER STOPPED RONGING MEYBE THERES SOMETHING WRONG WITH IT
Posted on Jan 18, 2008
SOURCE: Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Posted on Jun 18, 2008
  • 1462 Answers
SOURCE: Zanussi Ceramic hob ZKT641H front/main left zone does not heat up
can't give you much guidence - will be either regulator or the plate itself. no easy way to find out. you will have to remove the hob top and check for continuity thro the plate. ifplate is ok, then power up and check for supply to the plate. if no supply, then the regulator will be at fault
Posted on Aug 28, 2008
SOURCE: fagor hob touch control
Our hob has the same problem. I would really like to know the reason for this! Try using a rubber eraser instead of your finger - this works every time with our hob. Covering Up and Down arrows with the rubber, zeros it instantly just like using both fingers. Hope this helps.
Posted on Sep 16, 2009
I cannot unlock my fagor induction hob by pressing the plus and minus signs, what should I do?
check the keylock is not activated by holding down the key symbol for a period of 5 secs.
Nov 08, 2016 | Fagor Cooktops
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
One of the rings comes on when the hob is even turned off any idea why this is???
This would normally mean that the hotplate controller if faulty. It is not a common occurrence but it does happen.
Feb 10, 2011 | Fagor 31 in. VFA-78S Electric Cooktop
When turning on my 2 year old Neff induction Hob T4543N1 it displays a full set of E errors and cuts out it does after two attempts corect itself and function perfectly
I had flashing Es every time I turned the hob on - got worse and worse until unusable. Neff help line useless - service call cost ridiculous. My problem was the capacitor on the 5 volt power supply had failed. 5 volt supply was at 3.8 volts. Replaced the capacitor and the hob's now perfect - a joy to use. Only helps if you are tech savvy and willing to open the unit, but may give you some hope or point you in the right direction.t
Jul 28, 2010 | Neff Cooktops
Hob problems
Take a closer look at the wiring diagram on the base or in the book.Check you have put in the relevant links.If not wired properly you may only get half the hob working.
Hope this helps.
May 19, 2010 | Smeg 28 in. P752 Electric Cooktop
Fagor hob touch control
Jan 28, 2009 | Fagor 31 in. VFA-78S Electric Cooktop
Induction hob switching off
check that the hob is wired correctly underneath 1,2,3 should be linked together as live 4,5 as neutral and earth takes its place as earth,
if it is wired correctly then i m afraid the hob needs a new induction element it is all one complete unit on these hobs not seperate so your looking at £1000 + to fix it plus engineer call out charges
Dec 06, 2008 | Kuppersbusch K 23 in.EKE604.2 Electric...
Aug 27, 2008 | Zanussi 23 in. ZKT641H Electric Cooktop
Nov 04, 2007 | Neff 23 in. T1252 Electric Cooktop
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Fagor 28 in. VFA-70S Electric Cooktop Logo
Top Fagor Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Fagor Cooktop Expert? Answer questions, earn points and help others
