Question about ASUS P4XP-X Motherboard
Hello.when i plug in my mother board to power the fan is going to workwith out pushig the power key can you help me !??? my motherboard name is: asus xp4-x
  • ASUS Master
  • 11,800 Answers
Sorry, the motherboard is shorted. Since fixing it will be practically impossible you need a new one.
Posted on Nov 12, 2010
My mother board does not start. The fan movs for a fraction of second and powers off.
Hello, It sounds like your power supply is bad. You will have to get a diagram on your motherboard and take readings for your voltages going to the power plug on the motherboard.
Sep 30, 2015 | Computers & Internet
Installed new motherboard, but system would not boot. What is the problem. Did not receive a manual with motherboard at time of purchase.
Hello Dch,
After replacing the mother board if the system is not booting up then check the power connections on the mother board. The wires of power, restart buttons are properly connected to the motherboard. Also check the thermal grease which is used between cpu fan and cpu. If the thermal grease gets dried then clean the grease and apply the 2 drops of new thermal grease and properly lock the cpu fan.
Also visit the link provided below for more help :
http://downloadmirror.intel.com/15328/eng/D845GRG_ProductSupplement.pdf
Jun 29, 2011 | Gateway (4000792) Motherboard
No lights no power no fan
Please check if all the power cables are plugged in properly and check whether the fan in power supply is running after powering the system.
1. If the power supply fan is running then remove the memory( RAM) installed in your system, try changing the slot and if the issue still persists then the issue is with the motherboard and then you would need to check with the local technician.
2. In case the power supply fan is not running then removed the main power connector (the biggest one coming out from the power supply and going into the mother board) from the mother board. Check if the power supply fan runs or not, if it does then perform 'step 1' and if it doesn't then replace the power supply.
Regards
Anand Sachan
Nov 02, 2010 | Dell (1K529) Motherboard
Video card plug in does not work, plug in for cpu fan does not work
Hello sir Philip hi, need to go to BIOS, usually press F10, F2 or Del key on start up, set initial display first to PCIe, to send display to Video Card.
Aug 14, 2010 | Biostar TA790GX Motherboard
Power
Hello
If you're replacing a motherboard then the new motherboard has a jumper across the on/off jumpers. If this is used board then check to make sure the on/off jumper pins are not shorted. If OK boot up and go into BIOS. Make sure that any line stating Automatic Turn ON is off.
Sep 24, 2009 | Intel PGA478 Motherboard
Switch on problem no processor running
845gvsr no display given ram beep but ram ;ram ic and bios is ok what can i do sir
Jul 27, 2009 | Intel D845GVSR Motherboard
Power problems
Hi Tarry101,
Can not help you because you have not listed the model name of the motherboard & the model number. You can find this on the mother board. Depending on the age of the board the model number will be written on the board, usually written in white lettering. (Example), "Asus P4XP-X or AOpend VKM400Am-S".
If you have the manual for the motherboard you can find the model number there.
When you do find the model number click the Ask Me button under my nickname & I'll go over the connections for you.
Mike
May 06, 2008 | Intel Motherboard
Power supply and CPU fan problem
you dint mention the mother board u are using in some motherboards jumber setting can power up the system check the jumber setting in the mother board near ur front pannel pins in ur motherboard
Oct 21, 2007 | Biostar K8M800-M7A Motherboard
ASUS KBN-E MOTHER BOARD 754 processor 512mb ram
Try plugging the drives into another computer to see if they actually work, ie read discs etc if they do then try swapping the power supply out of your computer.. if this doesn't work then I would say your motherboard is dead. Good luck
Jun 02, 2007 | ASUS K8N4-E Deluxe Motherboard
ASUS P4XP-X Motherboard Logo
35 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
