Question about Singer Featherweight 140Q
Singer sewing machine
My singer sewing machine is sewing very loose stitches. I have tried adjusting the tension with no luck and my manual has very little for troubleshooting help. The top thread is also getting wrapped around the spool pin under the spool of thread while sewing and breaking. It has gotten to the point that I am unable to sew at all. Any ideas???
  • alietti Jun 18, 2008
    Thanks for your thoughts, after contacting singer it ended up being simple, I needed to use a smaller needle for the fabric I was using. I knew it had to be something silly like that. SO FAR, it seems to be working properly, the machine is new, only been used a few times so I HOPE I won't have to retime it. (I wouldn't know how to do that anyhow). Thanks for your help!
  • Anonymous Nov 11, 2008
    bobbin will not sew
5 Suggested Answers
  • 13 Answers
SOURCE: problem with singer prelude sewing machine!
Firstly make sure when you thread the machine you have the sewing foot in the up position or the thread will not sit in the tension and cause this problem. Also as it is a new machine it may have a small amount of oil from transport stopping the tension discs from separating. Try sliding the folded edge of a piece of fabric with the foot up through the tension unit it may clear the oil away.
Posted on Aug 27, 2008
SOURCE: Upper thread wraps around bobbin mechanism, while sewing
IT PROBABLY IS THREADED INCORRECTLY. GO SLOWLY BY THE DIAPHRAGM AND MAKE SURE IT IS THREADED CORRECTLY. ALSO MAKE SURE SPOOL PIN HOLDERS ARE IN PLACE THAT HELPS TO GUIDE THE THREAD CORRECTLY.
Posted on Sep 22, 2008
SOURCE: thread tension
I have had this problem when the bobbin was wound wrong and also when the machine was improperly threaded. Check your manual to make sure you hit all the threading points, but I think the most common one i've missed that caused this was the metal loop you thread immediately before threading the needle.
Posted on Nov 13, 2008
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
I'm having problems with the stitches. The top looks fine while I'm sewing, but when I turn if over the stitches look loose. I've double checked multiple times that the machine is threaded correctly. ...
this is a Cotton tension problem either you have threaded it correctly if so then the tension wants adjusting, also check the tension on your shuttle by doing a drop test by holding the cotton tail that come from your shuttle if you jerk nit up and down the cotton that runs through the tension spring and it should just slip a little bit if it drops down to the floor then the centre small screw needs to be turned a little bit at a time to get the required tension as stated above, but don't worry your sewing m/c is ok, It's as I say a cotton tension problem.
good luck
Mar 01, 2015 | Singer Confidence 7467 Mechanical Sewing...
Bobbin tension
adjust the top thread tension and see if that helps the bobbin tension
stitches.
here is a link for a free manual for the machine
http://www.singerco.com/uploads/download/545_7470-instruction-book-engfrespa.pdf
Feb 27, 2013 | SINGER 7470 Sewing Machine
Loose bottom stitches on Singer 1507
top tension must be adjusted to fix loose stitches of bottom stitches
adust the top tension one letter or number higher and sew on a scrap
piece of fabric till stitches look correct,, here is a free manual
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
Jan 06, 2013 | Singer 1507
The tension on my singer is loose
first try changing the needle
then adjust the top thread tension one number or letter and then
sew on a scrap piece of fabric till the stitch improves.
here's a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/561_2250-eng_spa_fre.pdf
Nov 10, 2012 | Singer 2250 Tradition
Singer 8770 beeps twice then stops stitching
do you have a manual?
try a new needle
adjust the top tension
try rethreading the machine top & bobbin
May 16, 2012 | Singer Curvy 8770 Electronic Sewing...
TENSION ADJUSTMENT ON SINGER 9836C
try adjusting the top thread tension to one number higher at a time until the stitches start looking right
also check with singer customer service for a instruction manual
Feb 23, 2012 | Singer 5050 Mechanical Sewing Machine
Featherweight 132Q Singer sewing machine. The top thread is loose. How do I fix that?
try adjusting the top thread tension to a lower number,,like if the machine tension is on 2 then take the tension up to 3 & if that doesn't give the correct tension go to 4 & see if that tension is good for the correct stitch
Aug 31, 2011 | Singer Featherweight 132Q Mechanical...
When making a straight stitch or Zigzag stitch, makes loops underneath the fabric This is for a Singer sewing machine model 5817c
Your top tensioner is too loose.make sure the thread runs through all the relevant eyes and then tighten the top tension little by little as you do a sample few stitches.
Feb 21, 2009 | Singer 5050 Mechanical Sewing Machine
Singer 221-1 stitching is good on bottom but not on top
pucker is caused by too loose or, to tight adjustment of: the thread tensioners both the bobbin tensioner and, the needle tensioner need to be adjusted: to adjust the needle tensioner turn the side knob clockwise is tighter counterclockwise loosens; the bobbin tensioner is a tiny screw on the bobbin holder adjust both tensioners until your stich loops' both top and, bottom are tight but, the machine does not break the thread
Feb 16, 2009 | Singer Featherweight II 117
Singer Featherweight 140Q Logo
32 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
