Question about Ryobi Garden
My ryobi RBL26BV wont start, i have changed the fuel exactly as per instructions, che cked the spark plug, help
  • 1,040 Answers
Here is a Link to one of my Tips:
http://www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Nov 13, 2010
Blower wont start, spark plug dry. appears not to be getting gas
Did you try checking for spark by putting a screwdriver in the spark plug wire socket and holding it close to the end of the plug, while someone pulls the starter rope?
Jun 24, 2014 | Ryobi Garden
My Ryobi 4 cyl 30cc leaf blower just quit starting. Has always started perfectly, but now it just wont start.
replace spark plug.if spark plug okay problem could be carburetor or air leak at fuel lines or check primer bulb for crack which cause air leak.any breaks in fuel line or primer bulb cause air leaks fuel system cause carb not get fuel run engine.
Sep 20, 2013 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I have just aqutred a used Ryobi rcs3535ca Thats proving impossible to start, it came with no manual or instruction book can you help?can I also purchase instruction and manual books? Regards CB
As this machine may have been unused for some time, drain the fuel tank and fill with fresh fuel, if no better, remove the spark plug and test for a spark with a suitable spark tester, if you do not have one, use a new spark plug, earth it to the cylinder, away from the spark plug hole, if it has no spark then a replacement ignition unit will be required, if there is a spark, is the plug getting wet with fuel, if not we have a fuel starvation issue, remove the fuel hose from inside the fuel tank and replace the filter on the end, if the plug is copletly soaked in fuel, it is flooded, put the ignition switch to off, now crank the engine ten or so times, leave the saw to dry out for an hour, replace the plug and go through the starting procedure again. Starting procedure on most machines are as follows, switch the ignition on, pull the choke fully out, if it has a fuel primer press this as many times as it takes to 3/4 fill the bulb, crank the engine until it fires once ( do not continue to crank with the choke out ), push the choke fully back in, now crank the engine until it fires up and runs.
Feb 10, 2011 | Ryobi Garden
My ryobi cs30 gas trimmer (3 years old) has been difficult to start this year, has been getting worse all year and now wont start. What's up?
Most likely it is the spark plug, but could be a dirty fuel system. I'd start with the spark plug then go from there. you can also use a good quality fuel injector cleaner in your gas to help keep all your small engine carbs clean. If the problem persists there is a fuel filter inside the gas tank that plugs onto the end of the fuel pick up line that could be clogged. Worst case a carb kit can be gotten for them for about $20 bucks. Hope this helps. Please vote yes, thank you.
Nov 01, 2010 | Ryobi Gas Hedge Trimmer
New Ryobi petrol c/saw wont start.
If it is brand new, sounds like you should return it for the retailer to have repaired.
Dec 05, 2009 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 24, 2009 | Ryobi Garden
Ryobi 40cc chainsaw
Have you checked for spark? Sounds as though your ignition module has quit.
Remove the plug, connect a jumper wire between the threaded part of the plug and the cooling fins, Switch the ignition on, take it into a dark room and pull the starter. You should see a spark at the tip of the plug. HTH
Lou
Sep 17, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Ryobi ss30 weedeater not starting after repair,to the primer bulb
Follow the instructions exactly. If it won't start, take out the spark plug to see if it is wet, or dry. If it is too wet, the motor may be flooded. If it is completely dry, you have to figure out why it's not getting gas. I am assuming you are pressing the bulb the recommended number of times, and that there is gasoline in the bulb, providing some resistance to your pushes with your thumb.
Jul 25, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
I just picked up a used ryobi rgbv3100 mulcher vacum blower ,it had no gas in it i put the oil gas mix in it ,followed the instructions on the blower ,but cant get it to start ,any ideas on what i can do?
test for spark.
while spark plug is out - put finger over hole see how much compression there is.
If good spark - look for holes in fuel line.
Jul 06, 2009 | Ryobi Garden
Garden Logo
131 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
