Question about Singer 3116 Simple
When I Try to sew all the thread on the bottom side of the fabric is long, stragglie, knotted & broken. I sew for approximately 3 seconds and then I can hear the machine grunt and then stop and I have the mess at the bottom of the fabric. This machine has never been used until now.
    Genius:
  • 1,788 Answers
It is in your top threading not in the tension discs right. Totally rethread as per your manual, now with the presser foot up, pull on the top thread, it should feed smoothly, now put the presser foot down, pull thread and it should barely move. Sometimes that seat the thread in the tension discs right. Read your manual and it will answer lots of questions for yopu. Hope that helps you.
Posted on Nov 12, 2010
  • Ani091769 Nov 28, 2010
    I have the same problem and I rethreaded the machine.....thread does flow smoothly with the foot up and down it barely moves, but I keep getting the clumps of thread underneath...I'm ready to return the machine...it's driving me nuts. It's only 2 days old
  • Mary Dunn Nov 28, 2010
    I think that it is a tension disc problem, I don't blame you for wanting to return it. Good luck with your new machine.
What am I doing wrong when the stitching on top of the material is ok and straight and the backside is knotting?
wrong bobbin tension , but amazingly its actually easier to adjust the top threads tension to compensate for it , use your tension knob to slowly adjust , try an inch , slowly adjust try an inch , and so on to get a top and bottom thread tension to match , this will need to be adjusted for each major change in fabric (aka , knits to woven )
Aug 17, 2016 | Sewing Machines
Thread keeps knotting up under the fabric (bobbin area)
Could be what is called thread nesting or bird nesting.
The first thing to try is installing a brand new needle in your machine. Then try the following suggestions:
sewing machine birdnesting
WHY IS THREAD BUNCHING UNDERNEATH MY FABRIC
3 Common Sewing Machine Problems and How to Fix Them
Nov 29, 2015 | Brother XL-5130 Mechanical Sewing Machine
I have juki 1541industrial machine . It started sewing upside down . Instead of nice stiching on top show side it on bottom. Any ideas
This is caused by the tension between the bobbin and needle threads being out of balance. If the knots between the stitches are on the bottom side, then you need to tighten your needle thread tension a little at a time until the knot is in middle of fabric. The reverse of this is if the knots are on the top, then either your bobbin tension is too loose or your needle thread tension is too tight. If this occurs, then loosen your needle thread a little at a time to see if knot goes down in middle of fabric. If it does not, then you need to increase the tension on your bobbin thread. This done by taking bobbin case out and tighten the small screw located in the middle of the spring on the side of the case. You only need a slight, steady pull on the bobbin thread - the more you put on the bobbin, the more you are going to have to put on the needle thread.
Feb 13, 2015 | Juki Sewing Machines
Cant get my bobbin in right position it keeps knotting up on inside of fabric
Top thread problem, Not enough tension on top=loops on the bottom of the fabric; too little tension on the bottom = loops on top of the fabric. Yes, I know it seems backwards. See: http://www.picturetrail.com/sfx/album/view/22521551
Dollars to donut holes, you either threaded the top of the machine with the presser foot down (it has to be UP to let the thread into the top tension), or you're trying to sew with the presser foot still up (which is an issue common to people trying to sew bulky seams).
Take the thread off the top of the machine, take out the bobbin case and give the machine a cleaning, rethread the machine, fetch up the bobbin thread and hold the bobbin and top thread ends together under and behind the presser foot for the first 2-3 stitches of each seam.
Jan 26, 2014 | Brother LS-2125 Mechanical Sewing Machine
Every time I try to sew my bobbin is knotting up. What can make this happen?
yes, & the thread may not be the right kind for the fabric, also the tension would have to be adjusted to meet the needs of the thread & fabric
Mar 13, 2012 | New Home HF-3000 Computerized Sewing...
Thread is knotting up on bottom of fabric causing it to stop
1.check the needle & see if it's bent--if so replace
2.lay the needle on a flat surface & roll the needle over if it doesn't roll true replace
3.check for blunt needle-if needle makes a popping sound when needle penetrates fabric
4.needle is not all way up in holder
on my mechanical sewing machine sometimes the threads come off the take up lever, that causes the thread to bunch up under something I'm working on
also check thread in bobbin
Jul 28, 2010 | Janome 4623 Mechanical Sewing Machine
How to tie knot using handy stitch machine how to tie off the thread so it won't come undone.
When you get to the end cut the threads long enough to be able to tie.
From the wrong side of the fabric, if you pull the thread slightly you will see the a loop from the top thread, pull this, so now both threads are on the wrong side, tie a square knot and cut close to knot, you can also put a drop of fabric glue on the knot to help secure it.
Hope this helps, and please rate if helpful or not
Moni
Sep 20, 2009 | As Seen On TV Handy Stitch Mechanical...
Thread is knotting up on the underside of the fabric - what do I adjust. I am using a Singer 438
Try pulling your top and bottom thread to the left side of the foot before you place the presser down and start sewing.
Sep 06, 2009 | Sewing Machines
Bobbin continues to pose problem - knotting thread underside of fabric,
In 99% of all problems with "bird's nesting" or "knotting" it is an issue of the thread coming out of the take up lever (at threading guide #3) (from the spool; through the first thread guide at #1 down to #2 and up to # 3) when the thread comes out of the take up lever, the machine can not regulate the thread and it floods the machien with thread and wraps itself around the bobbin case. OR! Your tension is too loose. Raise it. Your machine should preform perfect at tension #4 unless you are using speciality threads or fabrics.
ALWAYS be in the habit of threading your machine with presser foot up so that while threading between paths 1 and 2 you are certain to have the thread pass throught the tension disks.
This will happen on a $50.00 machine or a $5,000 machine. The thread needs to be regulated.
USE GOOD THREAD!
Thanks,
Bonnie
Oct 25, 2008 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 3116 Simple Logo
379 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
