Question about Cameras
My digital camera Kodak LS 743 was working fine. Now the camera comes on, the lens projects but it will not take photos. It took one photo this morning and flashed but then would not take anymore. What'sup?
  • 4 more comments
  • Linda Zerangue Nov 14, 2010
    I turned the camera on this morning and it flashed and took took one picture. Then, it would not take any more pictures. ????? It is possible that the auto button on top did get water in it but it should have dryed out by now. I did take the battery and card out for a while and thought that would work but it did not except for that one picture. I would not attempt to take the camera apart as you insturcted. Any more suggestions? Thanks!
    Yes, I did turn off the flash and try to take pictures and that does not work either.
  • Linda Zerangue Nov 20, 2010
    Any other suggestions since it is not the flash copacitor. It doesn't work with the flash off.
    OK. I will have to get a new camera. It takes the BEST photos for my oil paintings of beautiful Colorado. Thanks and Happy Thanksgiving.
  • Linda Zerangue Nov 21, 2010
    Good news! My husband decided to open the camera, jiggled the wires and the button to take pictures and the camera started to take pictures once again!!!!!!
    Opened the camera, jiggled the cables and the button and the camera now takes pictures once again! Thanks!
  • 13,433 Answers
what have you attempted so far?
Try turning off the automatic flash and shoot a few pictures without flash. If that solves the problem possibly the capacitor on the flash and gone bad and might need to be replaced.
If your camera is in warranty do noting and contact your dealer.
If its outside of warranty and the above worked, then you would have to take the camera apart, desolder the capcitor, and replace it with a new one that matches its voltage, UF rating and maximum temperature all shown on the side of the capacitor.
I don't recommend doing this if you have no previous experience.
Tools required:
A set of precision (small) screw drivers.
A plastic stick or case opening tool - your fingernails or a flat screw driver also works - but the screw driver will leave marks on the plastic casing.
Solder
Soldering iron
To get the casing apart you need to unscrew all the screws from the camera and check for additional screws under soft objects and labels, also remove the batteries, then the casing of the camera will be held in place with plastic clips that release by running your fingernail in the cracks of the casing.
Be very careful with all cables and wires inside the camera. some cables might be locked in place and need to be carefully released from the tabs on the side of the connector or on top of it.
Posted on Nov 12, 2010
  • 1 more comment
  • Ekse Nov 14, 2010
    did you try turning OFF the flash and then try taking a picture. It does not sound like it would have gotten wet.
  • Ekse Nov 20, 2010
    It seems the problem will be too complicated to repair at home. -- you can try reseting the camera's settings to defaults, but you will probably end up taking it to a repairer.
  • Ekse Nov 20, 2010
    okay, let me know if you need help with anything else.
Kodak ls 743 #E45 error
That is a lens error. Your warranty will not cover if you get an unauthorised KODAK TECH to repair this fault.
OoW. Repair´: 48,44 pounds,
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 07, 2009 | Kodak EasyShare LS443 Digital Camera
Horizontal banding on kodak z612 photos
if theres always a lines on the your photos it means that the camera is already defective, I strongly suggest Do not Dismantle the Lens, what you can do is to call kodak toll free 1 800 235 6325 and ask them to send your camera on their Repair center., Gudluck!
Oct 11, 2009 | Kodak EasyShare Z612 Digital Camera
I have a Kodak LS 443. Been a great camera until
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
May 13, 2009 | Kodak EasyShare M1033 Digital Camera
Kodak c340..water in lens...
i kept the camera on, that means the lens was open too..........after a good 4-5hours later when i checked it was back to ''foggy'', and another few hours later it was back to normal.........hurrah!!
Feb 02, 2009 | Kodak EasyShare One Digital Camera
My optical lens.....
You should contact Kodak didrectly to order parts for a Kodak camera. They will give you the contact information for your area, or maybe sell directly to you.
Jerry G.
Apr 07, 2008 | Kodak EasyShare Z740 Digital Camera
My screen reads "camera error # E21"
On my LS 743 Kodak Camera, that error refers to a lens mechanism problem. I was able to fix it by removing my front cover which had be come dented inward and short circuited some wiring. Re-shaping the cover fixed the problem. This will probably void your warranty...
Oct 03, 2006 | Kodak EasyShare DX7630 Digital Camera
Cameras Logo
32 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
