Question about Honeywell Heating & Cooling
I have a T87 that i was replacing, red with red, white with white none of the setting fron behind work, the thermostat started to smoke, i could not connect it, what to do?
    Genius:
  • 1,015 Answers
It sounds to me like you may have a defective thermostat. I would check wiring to furnace cotrol board on furnace and see if its is wired differently.If at this time of year for heat only red and white should do it. Hope this helps. Thanks
Posted on Nov 12, 2010
Bought new thermostat model ct87k but old Honeywell model I have was hook up by black and white wire not red and white , so how do I hook up.
The two wire Honeywell T87 and CT87 is nothing but a switch in a control circuit. Wire color is not important at all. What is important is the TERMINAL DESIGNATION those wires are hooked to. Soooo....take the wire off of the sub base of the old stat terminal marked 'R' and attach it to the new sub base terminal marked 'R' and so on. Wire COLOR means nothing at all in your case.
Oct 04, 2014 | Honeywell CT87K1004 Round Heat Only...
My air conditioner works find till it shuts off then furnace comes on blows heat even though thermostat set on cool
My guess is that the 24V has a problem. Has the thermostat been replaced? if so its wired wrong, if not then you have some wires touching- you'll have to check behind the thermostat and at the furnace for any 24v wires touching each other-in particular the red wire and the white wire.
Jul 04, 2014 | Heating & Cooling
My new honeywell T87N/T87K round is not turning on my heater
check for voltage then check connections sometimes the wire breaks and no power gets to the stat
Jan 06, 2010 | Honeywell Programmable Thermostat Heater
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
I've replaced my very old (mercury) Honeywell thermostat with a new one (round, Model: YCT87K1011), but I can't get it to control the temperature. If I connect the two wires one way, the furnace comes on...
Hey John, man that ole T87 has been around for a hundred years and I have installed many of them, but I cant remember the letters on the wiring. Seems to me that it is R-W-Y, any way you will use the R and W. I have a t87 at home still in the box and I could wait till I got home to help you but Im sure its the R and W terminal. Dont forget to set the heat anticipator. Set it the same as the current value of your gas or oil valve.
Nov 06, 2008 | Honeywell Heating & Cooling
Thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Oct 20, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
1993 Mercury Sable, white smoke, overheating
Good Day,
White some indicated that coolant is burning off. It could just be a simple leak which is burning off of the hot motor. It could also be a bad head gasket(probably what you don't wanna hear), One indication that it is the head gasket is white smoke coming out of the exhaust, this happens as coolant gets into the oil and is burned off then exhausted out the back. Possible causes for the overheating include, low coolant, coolant leak, thermostat, water pump and or water pump belt, or head gasket.
If I were you I would drain and flush the radiator, then fill it with new coolant, and change the thermostat, provided you have no white smoke coming out the exhaust.
hope this helps for now
Jul 05, 2008 | 1993 Mercury Sable
Heating & Cooling Logo
49 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
