Question about GPS
I have a Uniden XLT 560 scanner in my chiefs car- When i turn on the ignition after the car sits all night, the programmed channels are gone. Any Ideas
    Scholar:
  • 143 Answers
Sounds like the power feed goes dead, check the constant and the switched 12v are connected the right way.
Posted on Nov 12, 2010
Is there new police scanners for sale that work with Iowa up date on they new program?
yes uniden and wishtler i like uniden just easyer program gre whisler are night mares but each their own
May 15, 2016 | Uniden Brand New---Bc355c 800mhz...
What does it mean when a channel is "locked out"?
That is a setting that is used for channels that are constantly broadcasting but you don't want to scan them because they will stop the scanner. An example is the noaa weather channel. You may want to have it on the scanner as a channel but you don't want to scan it because the scanner will stop on it all the time.
Feb 25, 2015 | Uniden Bearcat 560xlt 560 Xlt 16ch Police...
How do program my bearcat BC860 XLT (put frequencies back in)
Try this link to the actual manual; http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/BC860XLTom.pdf
Sep 26, 2014 | Uniden "Bearcat 100 Channel 11 Band...
My scanners hasn't been turned on for sometime and wnat to program it but scanner is stuck on one channelBearcat Uniden 800Megs.police scanner model BC 855 XLT..
It used to be that you could reset a Uniden scanner by holding down the #2 and #9 buttons while turning on the radio - that MIGHT do a factory reset for you. Let me know.
May 07, 2014 | Uniden Radio Communications
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
How do i start scanning for channels on my bc 855 xlt scanner
Firstly, you need to program your favourite frequencies into it, before you can receive anything, all the info on setting up your scanner is in the user manual that came with your scanner, if you bought it new, that is.
Cheers,
Peter
Jul 26, 2011 | Uniden Bearcat Pro PC78LTW 40-Channels...
How to program a bc855xlt uniden bearcat scanning radio
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM; 118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed into its 50 memory channels. It does not have a VFO or dial mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel, press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1: Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning. To turn a bank on/off, press its number while in Scan Mode. Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR & re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY” in display. Same deselects.
• To lock out channel from scan, select it & press LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually, then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
BillB
Jan 19, 2010 | Uniden BC895XLT Base Scanner
How to install new freq in a Uniden BC 560XLT
For the BC 560 XLT, choose "MANUAL" mode on front of scanner. Push the manual button until u reach the number you want to program on your scanner ( 1-16) press the "E" button or "Enter" enter your number i.e. 555.555 in the six digit format with the decimal after the first 3 (industry standard) than press the "E" or "Enter" again. You're done. Hit scan or if u want you can press "REVIEW" to double check your number. Works the same for all numbers or if you want to replace a frequency with another.
Jul 09, 2009 | Uniden Radio Communications
GPS Logo
35 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
