Question about Weedeater 2 Speed Gas Blower FL1500LE ()
When i try and turn up the rpms on the weedeater it dies. It will run just fine on slow. Thank you.
  • 1,040 Answers
Here is a link to one of my Tips:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!!
Jim
Posted on Nov 13, 2010
Why does 1996 Volkswagen Jetta Gl start very hard and dies with quick throttle push? Slow and
What is the fuel pump pressure? When you put the throttle down, there is not enough fuel to match the air inlet and it dies.
Apr 06, 2015 | 1996 Volkswagen Jetta
Idle
MAYBE CHECK (MAF) MASS AIR FLOW SENSOR
Jun 29, 2013 | 2000 Chevrolet Tracker
Weedeater 300 series lawnmower
which engine does it have look where the govern spring
attaches to the throttle where it hook to the tang it is bend
able have to be careful they only should be at 3600 rpms
Oct 15, 2017 | Garden
Will not idel. Car dies when I slow to a stop. The car starts fine but dies out. If I hold pressure on the gas It will stay running. Once I get the car in drive and take off the car runs fine, but if I...
Sounds like the Idle/Air Control Valve is bad. If you are able to remove it, you may find that it has some dirt or build-up in it and be able to clean it for it to work. This would more than likely be a temp. fix. Chances are you'll have to buy a new one.
May 21, 2011 | 2003 Suzuki Aerio
I have a TroyBilt trimmer Model TB25CS 2 cycle. I have replaced the carb mounting gaskets and rebuilt the Zama Carb. It idles fine, but when I give it full throttle it just dies. There is a white and...
first remove your muffler and check to see if screen is plugged in exhaust..this will cause it not to rev. Also if you rebuilt your carb you neglected to pull your jets out and flush them out, pull both caps off adj screws with small screwdriver and try to adj "H" turn counterclockwise 1/8to 1/4 turn and see if it improves any if so keep turning till rpms start to slow back down then slowly turn back clockwise just till on edge of rpms speeding back up ,also did you change your fuel filter? hope this helps you!
Apr 14, 2011 | Troy Garden
I have a slow-starting f555rc stihl weedeater. Is there a manual online for making gas feed adjustments?
There are probably limiters on the adjustments.(epa). If not 1 turn out on low speed 1and a quarter on high speed. Never adjust for max rpms this will lean it out.(could burn it up).
Sep 30, 2010 | Garden
Carb settings mixture jets on a homelite weedeater st155
ther is no set setting but to get it to run so it can be adjusted. lightly close the high off then open the low about two turns. try to start if starts slowly adust the low screw till it runs normal with the choke all the way off. then start to add throttle while turning the high out till regiured rpms ar reached with no misses. this takes awhile even fo a seasoned mech and may require several attempts
Dec 24, 2009 | Garden
Same Problem
try winding the mixture screws out a little
Jun 14, 2009 | Poulan Weedeater/Electric Trimmer 4.1 Amp
Weedeater 2 Speed Gas Blower FL1500LE () Logo
414 people viewed this question
Top Weedeater Garden Experts
Matt Olenzek
Matt Olenzek
ray gallant
 steve
steve
Are you a Weedeater Garden Expert? Answer questions, earn points and help others
