Question about Panasonic KXDT333 Phone
How can I change the time on the display - its still summer time
  • Panasonic Master
  • 2,460 Answers
The TDA/NCP system time is changed from the phone allowed programming. It can be one or all, but the main phone (ext 101) can do it. When you find the one that works, press PROGRAM **1234 If it doesn't work, then you don't have the right phone. When it says Sys Pgn No? dial 000.
Then use the NEXT, keypad, and ENTER keys to change your time.
Just pick up the handset and drop it back down to exit programming
Carl
Posted on Nov 12, 2010
How can I set the time zone?
The DST is only based on GMT.
When daylight saving time (summer time) begins
The following models employ the Automatic Daylight Saving Time/Summer Time adjustment. The DST indicator in the display appears in the display at the beginning of the daylight saving time (summer time), and disappears at the end of it. Automatic DST/Summer Time adjustment is based on GMT (Greenwich Mean Time).
• Summer time begins at: 1:00 AM on the final Sunday of March.
• Standard time begins at: 2:00 AM on the final Sunday of October
To cancel the Automatic DST/ Summer Time adjustment and
to set DST display manually
The Automatic DST/Summer Time adjustment can be cancelled.
Press and hold DST for more than 3 seconds while the clock is displayed.
A beep sounds, and "Aut t OFF" appears in the display to show that the Automatic DST/Summer Time adjustment is cancelled. The display returns to the clock.
Notes
• The change timing of Automatic DST/Summer Time adjustment employed by the unit (see above) is subjected to variation by circumstances and the law in each country/region. In such a case, cancel the Automatic DST/Summer Time adjustment and
set DST display manually as necessary. The customer who lives in the country/region that has not introduced the daylight saving time (summer time) must cancel Automatic DST/Summer Time adjustment before using the set.
• To activate the Automatic DST/Summer Time adjustment again, press and hold DST for more than 3 seconds. A beep sounds, and "Aut t On" appears in the display to show that the Automatic DST/
Summer Time adjustment is activated. The display returns to the clock.
• To change the display to the daylight saving time (summer time) manually, see "To change the display to the daylight saving time (summer time) indication."
Sony ICF ICF C318 Operating Instructions Operating The Radio Setting The...
Apr 21, 2016 | Sony ICF-C318 Dream Machine Alarm Clock...
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
This unit employs Automatic Daylight Saving
indicator appears in the display at the beginning
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
DST
for at
least 3 seconds. A beep sounds, and "Aut
automatic DST/summer time adjustment is
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
May 24, 2015 | Sony SY-ICF-C414 Clock Radio
How to change clock on a kindle fire to british summer time
Step 1: Pull Down upper Status Bar - More +
Step 2: Select Date and Time
Step 3: Select Change Timezone
Step 4: Change to your preferred Timezone (British Summer Time is +1 GMT)
Mar 31, 2013 | Amazon Kindle Fire HD
How do i change the time on the clock?
Hi the details are below. Hope it helps I have added a link for the manual at the very bottom, Good luck with it.....
Time Adjusts the systems clock. The time difference (+, -) between the time originally set in your navigation system is set here. You can also select summer time On/Off. > Time settings, (See page 131) Summer Time Choose whether or not to take summer time into account. On: Summer time is taken into account. Off* Summer time is not taken into account...... When the period of summer time comes, or when the summer time ends, your navigation system does not automatically change the summer time setting. > Change the summer time setting, (see Page 131)
To set the time difference, touch "+" or ."-" The time difference between the time originally set in the navigation system (Pacific Standard Time) and the current location of your vehicle is shown. If necessary, adjust the time difference. Touching "+" or "-" changes the time difference display in one-hour increments. The time difference can be set from +3 to -3 hours. If necessary, set to summer time. Daylight Saving Time (DST) is off by default. Touch "Off" to change the time if you are in the daylight saving period. This turns the display below summer time "On". 9 To complete the setting, touch "Back". The map of your surroundings appears. This completes the setup of your navigation system. Chapter 1 explains the basic operation of your navigation system. > To change the time later, (see page 75)
The link to manual here:- http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/417273154AVICD3OperationManual0221.pdf
Mar 29, 2011 | Pioneer AVIC-D3 Car DVD Player
To simply change the time from winter to summer
if you are trying to change for one phone its not possible because the time changes for all the phones and if that is ok with you go to asa and give the command change time in that it will give you the options.
May 20, 2010 | AT&T Lucent MLS-12D Phone
How do I correct the displayed time
hello,kindly follow the steps below,
MENU>SETTINGS>TIME AND DATE>THEN YOU CLICK ON TIME>THEN YOU ACCESS THE TIME ZONE>AFTER THIS YOU CLICK ON THE GMT.and definately your mobile phone time will then work perfectly again.
hanks for using fixya,
you are highly appreciated.
Apr 05, 2010 | Samsung J700 Cellular Phone
Major lightening strike on buliding in the summer time. Knocke out a lot of systems. Phone system unable to set correct time and date on the phone in my office and the instruction booklet has nothing...
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Oct 20, 2009 | Avaya Lucent Partner 616 Phone
Changing time on navigation
Time
(+, –) between the time originally set in your
Navigation System is set here.
➲ Time settings ➞ Page 108
Summer Time
account.
On :
Off* :
❒ When the period of summer time comes, or
when the summer time ends, your Navigation
System does not automatically change the
➲ Change the summer time setting ➞ Page 108
Modify Current Location
Touch the screen to adjust the current position
and direction of the vehicle displayed on the
map.
Hardware Info
Touch “Hardware Info” in the Setting Menu to
display.
Connection Status
Connection Status ➞ Page 61
3D Calibration
3D Calibration ➞ Page 60
Service Info Screen
Displays the disc production number and version
information.
Mar 14, 2009 | Pioneer AVIC-D1 In-Dash Mobile Navigation...
Clock problem
Hi Ido,
- turn the tape deck/radio off.
- then press 'mode' on the display
- use the 'arrow keys' to set the time
- up and down - change figure
- left and right - select minutes/hours
- press 'trip' to return back to normal
Hope this helps,
Eitan.
May 27, 2008 | 2007 Toyota Yaris
How to change the hour in the clock
Make sure the outside temperature is displayed under the clock, then hold DISP button for 5 secs, release and hours flash.
Panasonic KXDT333   Phone Logo
420 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
