Question about Epson EMP 50 Multimedia Projector
No image: Suddenly in the middle of a session the image became very faint coloured lines. I was not near the EMP50 projector or the Compaq laptop. The bulb seems fine. I've gone thro' the manual and done all the checks there. Got someone in to verify the settings. Changed to another laptop. Tried a different connecting cable. Still no image. I've been using the projector & laptop for a year without problems. What can I do next?
  • conroynaas Nov 12, 2010
    Thanks, Azraelsrl ,
    I use this for the basic purpose of projecting photos on a screen in order to paint portraits. Can't afford to spend more than Euro200 total. Any suggestion?
    regards,
    Kevin
    Thanks Azraelsri
  • Epson Master
  • 11,800 Answers
This projector uses 3 small LCD panels to generate the image. The possibility that all of them were failing at the exact same time are astronomically low. Since that can't happen and you have checked everything outside the projector itself that could cause ithe image corruption you see then the only thing left is the image processor of the projector - its job is to take the AV signal and convert it to a format that can be used to control the 3 LCD panes. In your case the processor is no longer doing that - it has failed. Since it can't be fixed or replaced to repair the projector the entire mainboard will have to be replaced.
This can be done but it's not an economically sound decision - it will cost you more than a new projector. Time for a new one.
Posted on Nov 12, 2010
  • Azrael SRL Nov 12, 2010
    For this money you can only get second-hand or refurbished units and in that case the quality is about the same for all. For a cheaper price try at your local shops or online.
How to remove smears around edge of image projected on Optoma DS316L?
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jun 12, 2016 | Optoma DS316L DLP Projector
Colours have gone and picture quality became very dark. Now wont stay on for very long...will switch off after about 10 mins of viewing.
Unfortunately dim image and premature shut-off are normally due to a defective lamp assembly. I'd recommend removing the lamp and inspecting its condition. You'll notice black corrosion build up or a bubble is starting to form around the filament of the bulb if it is what's causing the dim image/premature shut-off.
Aug 01, 2011 | Panasonic PT-AX200U Projector
The image of my optoma hd803 became inverted.
Go into menu settings, look for a menu item that has to do with screen size and orientation. You'll be looking for the option to rotate the image for mounting the projector upside down on a ceiling mount.
Feb 06, 2010 | Optoma HD803 DLP Projector
Faint black lines running vertically
did you try unplugging everything and resetting your cable box. then plugging it back in,
i got some faint boxes yesterday and that did the trick
Jan 02, 2009 | Toshiba 42HL196 42 in. LCD HDTV
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Greenish picture when i play my Compaq Ipaq MP3800 projector
The greenish image is due just by one sof the terminals of the cable. You just need to replace it. Or try anothr RGB cable and look what happen.
Nov 18, 2008 | Televison & Video
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
Sep 08, 2008 | Mitsubishi SL4SU ColorView Multimedia...
Lcd proctor image
Disconnect the computer and then run projector if it still comes then service your projector.
Viren
Sep 11, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Epson EMP 50 Multimedia Projector Logo
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
