Try unplugging the router for 1-2 minutes, then plugging it back in. This will allow the router to reset its connections and should improve its performance. Also, try relocating the router to a more central location and pointing the antenna away from walls or other sources of interference.
Please let me know how you make out.
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
or
if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
hope this helps
