Question about Canon PIXMA MP830 All-In-One InkJet Printer
One of the heads are leaking dropping ink on the back of the page
  • Marie Siravo
    Marie Siravo Nov 12, 2010
    I need to stop the leak i already cleaned it many times.
  • 132 Answers
Ink is leaked. Clean carefully paper path with soft cloth.
Posted on Nov 12, 2010
EPSON STYLUS PRO 7600 Leaking ink One of my
sir the printer head of your printer is already thin... try to change the printer head...
Oct 21, 2013 | Epson Stylus Pro 7600 InkJet Printer
I have changed the empty ink cartridges but each time I try to print, it tells me that they are empty and to go to hp.com/recycle. Again, the ink cartridges are brand new. I was able to go to the...
Are you sure catridges are brand new? check any where ink is leaking? if its leaking try to arrest it or replace ink tube assm.Dont try to clean print heads every time it will consumes ink...
Sep 07, 2011 | HP Photosmart C6180 All-In-One InkJet...
Streaks through the printed page
Description of Problem 100000013725
The ink is leaking out of the cartridge or ink leaked inside my machine.what should I do?
Description of Solution 200000017618
Brother strongly recommends that customers do not use generic ink or refill their Brother ink cartridges. Using non-Brother supplies may affect the hardware performance, print quality and machine reliability since the ink formulation in genuine Brother ink cartridges prevent smearing and clogging of the print head. The Brother limited warranty does not apply to any problem that was caused by the use of unauthorizedthird party ink and/or cartridges.
If the ink cartridge is new and has not been installed into the machine, please do not install the ink cartridge. Place the ink cartridge back into the ink cartridge packaging and call the Brother Customer Service Department at 1-800-284-4329 for assistance.
If the ink cartridge has been installed into the machine and ink has leaked inside the machine, do not remove the ink cartridge from the machine.
Please contact Brother Customer Service at 1-877-Brother (1-877-276-8437) Monday through Friday, 9:00am - 7:00pm EST, excluding holidays.
Jul 19, 2010 | Brother MFC 240C All-In-One InkJet Printer
It seems to work, paper comes out, ink cartridge moves freely,it just wont print
I have had this problem myself, the ink has dried inside the print head, I used isopropyl alchohol (IPA) after removing the head and carefully cleaned the head using a soft cloth, also I dripped a few small drops onto the mesh where the ink goes from the cartridges into the head itself, placed it back into the printer, popped in some brand new cartridges and printed a good few test pages to clear it all out, do this quite quickly so as not to degrade anything inside the head.
hope this helps you
Oct 08, 2009 | Canon PIXMA iP90 Mobile Printer
Colors are not printing correctly. put in a new cartridge, test page came back with only black, yellow, and blue. fiddled around with it a bit to no avail. put in anther new cartridge, test page came...
I use a small diameter silicone tube to carefully "prime" stubborn new carts by sucking a drop of ink out of the tiny print holes in the printhead part of the cart. Ink can dry at the head and since these carts work by electrical excitation, there needs to be liquid of each color at the holes. Slap a drop of water with your finger on the holes to start easy hesitant ones. Do not get the contacts wet.
Jun 04, 2009 | HP DeskJet 932c InkJet Printer
Black ink spot on printed page
Does this ink spot persist if you change the black cartridge for a new one? If not, it's just a faulty cartridge seal. If it persists, you must have a leak from the print-head somewhere - this would probably require you to dismantle the printer to locate it. For example, the waste ink pipe may be blocked and the head is just swimming in black ink (the one you use the most).
Please report back if you need further help on this.
May 20, 2009 | Epson Stylus C84 InkJet Printer
Nozzle Clogging & Black Cartridge Leaking
Hi e-margaret. There's a bit of confusion here. Horizontal banding is due to LACK of ink flow to the paper. "Splodging" is due to too much. The former can be due to blocked/faulty print head nozzles or a faulty/empty-ish cartridge, or some less common problem like the waste ink pipe blocked. The latter is usually due to a leaking cartridge.
The first job is to mop up ink slopping around under the print head. Cut some strips of kitchen towel and fold them into 3 layers so you have a strip about 2 cm wide. Place them on the print head track. Turn on the printer, and as soon as the print head moves, pull out the power cord from the back of the printer. Now you should be able to move the print head carefully by hand too and fro over the towels. Repeat this with clean towel strips until most of the surplus ink is cleaned up. Remove the towel strips, replug in the power chord and switch the printer back on. Do a head clean cycle and nozzle check 3 or 4 times. If the nozzle check output looks OK, try a test print of a text document
If things are still not OK, report back on what happens in a new comment. If my instructions are not clear enough, please post a new comment asking for clarification.
Apr 22, 2009 | Epson Stylus C86 InkJet Printer
When I print, black ink comes out over the page
what printer is it and is it using ink/cartridge? Try taking out the ink and check to see if its leaking or anything like that. Clean the printer and print a couple of pages to see if the problem is resolved. you may also need to replace the ink/cartridge. good luck.
Dec 11, 2008 | Office Equipment & Supplies
Newly Installed 7680
probably you did nothing wring, I seen a few of these cartridges leak - HP should replace the machine if the damage was caused by original cartridges.
Apr 21, 2008 | HP Officejet Pro L7680 All-In-One Printer
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
50 people viewed this question
old marine
old marine
