I have a GE washer, model # S5100D0WW, that has recently had some repairs done to it. The transmission, seals, bearings, inner tub base, etc. have all bee replaced, in other words the unit has been pretty much rebuilt or so we thought. Once all of the parts were changed out the washer worked fine and no leaks. Now, a few weeks later, it will not go into the spin cycle. Washes great but when we try to put it into the spin cycle, the motor seems to lock up (front panel off and visual inspection of the process). Might the new transmission be the problem or its there some other problem we do not know about? Your help in this matter is greatly appreciate.
  • Dean Corse Nov 12, 2010
    Thank you for your comments. Will follow your recommendations.
    President:
  • 1,218 Answers
Good day,
Could well be the transmission. You should have the tech who performed the repair return. If it's only been a few weeks then both parts and labor would still be under warranty. I wouldn't force it, if it locks up, since that could damage the motor which wouldn't be covered.
All the mechanical parts have been replaced, so it's likely one of them failed.
Posted on Nov 12, 2010
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Fridge washer GLWS1349AS0, have inner tub out, trunion lifted, not off yet due to slight rust. How do I change spin bearing and tub seal? thanks.
To remove the trunion totally reattach the inner tub to it and twist the inner tub,with the tub attached it gives you much more leverage to twist and pull the trunion off. After its off pull the small brass ring with the O seal in it up the transmission shaft and pop the tub seal off. To replace tub bearing remove the bolts on the side of the side of the outer tub off from the tub support and pull tub off of trans. shaft. to remove bearing flip tub upside down and remove the 2 screws from the tabs on bearing and turn tub back right side up and use a screwdriver on the top of bearing and knock it out of outer tub,push new bearing in by hand most of the way,being sure the tabs on bearing is lined up w/notches on tub and use old bearing placed on top of new one and drive it down all the way,reinstall screws into tabs. All the surface rust should be sanded off of trans shaft. Re install outer tub and secure with the bolts into tub support. push main tub seal into flange with normal palm pressure,install new brass ring and MAKE SURE O RING DOESNT POP OUT OF IT ( a little dawn,palmolive joy liquid dishwashing soap around inner part of o ring inside of brass ring will help it slip on easily) I use the old brass ring and press it over new brass ring to assist in o ring not popping out,once new brass ring is inserted ok and oring in place remove and discard old brass ring. Reistall trunion and inner tub ECT ECT ECT
Gene
Aug 12, 2011 | Frigidaire GLWS1349A Top Load Washer
Maytag Washer Model LAT9416AAE - Top tub seal is leaking or where the tub and the shaft meet is leaking. What would the cost be for parts and repair (service fees, labor, etc.)?
The usual charge when i have repaired that is around $375
in addation to the seal a tub bearing would be required since the seal has leaked it very likely has rusted the bearing. To replace those both the inner and outer tub have to come apart,the breakdown would be
Parts--$150
Service Fee $75
Labor $100
labor and service fees vary from company to company and that is probably low,yet it is a great washer and may be well worth investing in to repair
Aug 06, 2011 | Maytag LAT3600A Top Load Washer
My machine gets out of balance when in the spin cycle no mater what size of load or what type of clothing being washed. Model # A308 Ser# 870406GP. I have taken the front off and determined that the...
Hi and welcome to FixYa, I am Kelly.
Nice to see there are some A series washer still in service. Ok here goes on the what can cause this problem list.
1. The iiner wash tub.
a. Some one with small fingers needs to feel in between the outer tub cover and and the inner wash tub for missing chunks of the top of the wash tub ring. It is filled with concrete FYI. If the tub corroded and it tossed a bit of the top balance ring you will always have an off balance condition in the spin cycle.
b. Also grab the top of the inner wash tub and attempt to teeter just the inner wash tub. If it teeters there is a problem under the inner wash tub. This can be because of the mounting stem
item 24 of this link http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416 or the tub bearing Item 18 of the same link.
If the tub bearing is bad the outer wash tub can move indepently of the inner wash tub. The should move as one. Grab the agitator and press on 3 sides of the outer wash tub with opposing force and check for excessive moment. (FYI the mounting stem and tub bearing repairs ar not for the novice repair person.)
2. The CORK damper pads on the top of the machine base are worn. Item 22 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789 Pushing the outer wahs tub off center and against the cabinet should result in the outer wash tub retring to near center (within 2 inches as viewed from the top) If it does not return to near center there is a problem with the damper pads.
_________________________________________________________________________________
Here are my thoughts on your washer and what to consider. If your unit is in fair material condition and you do not have lots and LOTS of rust on the base I would repair it. Honestly this machine will outlast you if you have it "re-furbished" Refurbishment would be
A. New Tub Bearing
B. Mounting Stem
C. O-ring replaced on agitator shaft inside the transmission lower housing PN 2-10286
(^ ^ ^ ^ -- Must purchase transmission grease.
(there is the possibility that the Transmission drive gear would need replaced PN 2-10315)
D. Damper Pad Kit.
E. Motor mount spring and roller kit PN 2-5000
F. Both belts Items 18 and 19 this link: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=26789&diagram_id=28323416#d28323416
G: Water injector kit.. No part number but still available.
I know this is probably a lot more information that you wanted but.. the bottom line is you own one of the "Cadillacs of Maytag." As long as the macine base and cabinet are in fair shape you can keep it in service with parts that are always available.
To fix your current problem it will show up when performing steps 1 and 2 at the top of the post. The unit will most likely have to have the inner and outer tubs removed to correct the problem and it involves about 2 hours of labor. You may have to find a very experienced repair person to have your unit re-furbished IF and I reiterate IF it ever comes to that.
Thanks for choosing FixYa,
Kelly
Feb 24, 2011 | Maytag Washing Machines
My maytag washer model #sav5710aww shakes badly and
if its a neptune front load washer you need new tub lip seal and bearings for the drum as the seal is leaking water into the bearings that hold the inner drum,it will only get worse,you need to remove the inner drumto replace the seals and bearing it takes from 2 to 6 hours depending how hard the old bearings come out of the race
Apr 02, 2010 | Washing Machines
Looking for replacement bearings for the outer tub to inner tub on our Maytag FAV6800AWW, S/N 13389034ET. Don't want to replace the whole outer tub assy.
It sounds like you may have to replace the Outer Tub to replace the Outer Tub bearing .....ain't that just peachy.....good job Maytag design team.
If you are the original owner I would press Maytag hard to replace the Outer Tub based on the Outer tub Bearing failure. Their warranty states third thru tenth year Drive Motor, Outer Tub and Sealed Transmission. I’m sure you will need to have a certified Maytag repair service tech certify the failure and fix action required. Why should an Outer Tub bearing replacement cost you $430. Another poor design issue of this machine.
Sep 25, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Inner tub broke away from outer tub casing
Time for the dump. Probably need a new tub lock nut but there may be more damage to the transmission or tub seal which will leak water and it may not be worth the $100 service call for a Tech to tell you you need a new washer. Good time to buy appliances right now, try to get free installation!
Jul 21, 2009 | Frigidaire FWS1339A Top Load Washer
GE washer Model WDSR2080D5WW Transmission shaft wobbles
If you can't loosen the nut, you can break it with a hammer and a metal chisel. Tub nut is cheap. Grease on clothes = new transmission time.
By the way, after you remove the inner tub,.... you have to take the entire outer tub assembly out of the washer, flip it upside down, remove the yoke that holds the motor onto the outer tub, and pull the transmission out through the bottom of the outer tub.
Jun 11, 2009 | GE WDSR2080D Top Load Washer
Noisy when spinning
The noise coming from this machine as it spins is due to -- If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
May 07, 2009 | GE WJSR2070B Top Load Washer
GE WBXR2060V1WW leak_transmission shaft and tub
The tub seal is leaking, often this damages the transmission. A new tub seal comes with the transmission this page should help http://www.appliance-repair-it.com/GE-washer-disassembly.html
Nov 12, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
