Question about Dell 2300MP Multimedia Projector
Dell 2300mp I have a dell 2300mp projector. I replaced the lamp with a brand new one. I plug the power cord and the green light on the power button comes on flashing. I press the power button and the light turns solid green but the lamp does not turn on and the fan and color wheel does not turn on. Please help. I just bought the projector second hand and a brand new lamo.
    President:
  • 1,257 Answers
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (dell 2300mp - c00589410.gif ) or down ( ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Posted on Jun 18, 2008
  • Deeps . Jun 18, 2008
    To reset the lamp usage timer
    After replacing the projector lamp assembly, reset the lamp usage timer. Use the Unifi software
    on-screen menu or the remote control to access the projector’s on-screen display.
    1. Press the Settings button on the Unifi onscreen
    interface, and then select Advanced
    settings.
    OR
    Press the remote control’s Info button.
    2. Select the Setup menu (wrench icon).
    3. Select the Reset Lamp HRS option.
    4. Press Yes to confirm.
  • Dell Master
  • 13,433 Answers
Something is wrong in the projector you should have it inspected, theres not much I can suggest without haveing a look at it. I suppose you have had it unpluged for a while and tryed again.
Self-diagnostic for video
  • Dell 2300MP Projector provides self-diagnostic test of the projector video display (for Video, S-video, Component-i). Use this advanced feature for preliminary self-diagnostic on your projector when encountering a display problem for video.
  • After turning on the projector, press "+" and "-" buttons on the control panel simultaneously and release the buttons when screen goes blank.
  • Press "+" and "-" buttons again to exit the diagnostic mode.
  • While in Self-diagnostic mode, the screen will run a seven-color-cycle test as following: "Red--> Green--> Blue--> White--> Watchet Blue--> Dark Green--> Yellow." Ensure that the colors of the test pattern are correct. Contact Dell if the colors are not displayed correctly.
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Dell 2400 MP projector lamp problem
could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Feb 03, 2009 | Dell 2300MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
Dell 2300mp projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
The projector lamp comes on (amber color) no image
I was told by an expert that the fan should come on as soon as heat starts to come on. You should never turn a projector off with out the fan running for a while to cool the bulb down. Each projector is different but the fan has to operate on then all. There is so much heat in the bulbs that air has to keep them cool when they are operating as well have to cool gradually when they are shut down.
Mar 02, 2017 | Dell 2300MP Multimedia Projector
Dell 2300MP - no power
It looks like you may have a loose contact somewhere around the AC input. Try pushing the AC cord or wiggle it gently, if power comes back on; you have a loose connection.
Jan 16, 2008 | Dell 2300MP Multimedia Projector
No power to my dell 2300mp
The fuse is a short round maroon colored part to the left of the power plug looking at the power supply module from the direction that you would connect the cord to. it is labeled F1 and it is a 4a 250v. This is not the problem with my power supply though. I suspect one of the components under the heatsink is bad.
as you all know don't bother calling dell.
Nov 02, 2007 | Dell 2300MP Multimedia Projector
DELL 2300 MP NOT TURNING ON
Have the same problem here. Have two of these units. Took the bulb out of the one that had the Lamp light on, and put it in the other projector. The other projector worked perfectly. I have three bulbs, they all work in the one projector, they all cause Lamp Light in the other one. The manual states nothing about hard resetting the unit. Also note that, the fans do not power up instantly on power on, they come on about 5 seconds after pressing the power button.
Aug 30, 2007 | Dell 2300MP Replacement Projector Lamp -...
Dell 2300MP Multimedia Projector Logo
559 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
