Question about LG WM-2077H Front Load Washer
My LG Tromm WM2487HWM died... Yes, it is plugged into a working outlet. Is there a fuse panel and if so, where is it located and where can I buy a fuse? The washer currently has a half washed load of towels in it, so time is of the essence.... Thank you
4 Suggested Answers
SOURCE: We have an LG Tromm WM2487HWM that has an upside
We have the same problem on our washer - same model as yours. Home Depot has the warranty on this thank goodness we bought it. They replaced the motor and water pump - didn't fix the problem longer than a month. A new repairman has come out and says we need a new heater and thermistor (whatever that is - I checked - not a thermostat but possibly related??) Approx a $300 fix. Good luck.
Posted on Jul 22, 2009
  • 6277 Answers
SOURCE: LG Tromm washing machine model WM2487HWM has an
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
Posted on Mar 23, 2011
  • 489 Answers
SOURCE: I HAVE A LG TROMM FRONT LOAD WASHER. WHEN I PUSH
You have a bad control board and will need to be replaced. The relay switch in the board has failed.
Posted on Jul 09, 2011
Why is there no power gegtting to my lg washer?
hi look inside the washer on the circuit board for a glass fuse, or there may be a soldered in one called a wickman fuse, you will need a multimeter to test them!! hope it helps
regards
shaun
May 12, 2014 | LG Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_b77d19396bfe2249
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
We have an LG Tromm Steamwasher WM2487HWM . 4.0 cu ft front loader....I see a lot of complaints about mildew and smell...we have the same problem....is it safe to take teh rubber seal off the washer to...
Replace the boot with new. While you have top and front off to replace boot, hose the drum down with a hose on stream. Remove filter clean out as you hose it down. Btw, there is no cleaning off the boot if it has mildew/mold on it.. it's slightly porous and no eliminating it
Aug 05, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My LG LMVM2055 just stopped working. i have checked the fuse box and everything is fine. i unplugged the microwave and plugged it into a working outlet and it still does not work. is there an internal...
yes there is a fuse behind the control panel area. where the cord goes inside the unit there is a fuse bloack and a 20 amp fuse ...may have lucked out and just need to replace fuse...unfortunately you have to do some disassembly to get to it ...good luck to you
Jan 09, 2011 | LG LMVM2055 Convection/Microwave Oven
Rear bearing is going out (very loud on spin). Tech said it would be $900.00 to replace. Is it that hard to replace a rear bearing? Does the whole machine have to be disassembled, etc. About how much is...
rear bearing is generally included with the rear outer drum ***'y. seals and bearings are already pressed into it. it will require much disassembly of machine. hopefully, the motor rotor/stator/drum spider shaft is not damaged too.
Aug 13, 2010 | LG WM2487H Front Load Washer
We have an LG Tromm WM2487HWM that has an upside down f and e error code. The machine will sometimes start and then quit after about a minute into the run. Unplugging and replugging in does not seem to...
Jun 20, 2009 | LG Washing Machines
Need Directions on how to use machine
Hello maemaez4,
I will put a link below which will take you to a web page with a downloadable PDF owners manual for the Tromm. You will have 4 different options,( WM2487HRM, WM2487HRMA, WM2487HWM, WM2487HWMA ) just click on the model of the one you have and it will give you the correct manual. Hope this is what you were looking for.
http://us.lge.com/support/download/search/1000000376_EN_OM_WM2487.jhtml
Thanks,
edgin96
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
May 19, 2009 | LG Washing Machines
Lg tromm front load dryer dlg5988w
dryer has two fuses check both circuit breakers one is for heating the other is for the plug this fixed my front load lg this gives you the heat that you need to dry your clothes
Mar 01, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
53 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
