My Zyxel p600 can't connect to my Aztech HW550-3g Router
  • 8404 Answers
SOURCE: status on HW550-3G : No Modem / Unsupported Modem
This machine should run right out of the box.
No user normally required
No pass usually required
If there is a pass ... it is usually "Admin"
Get Network Magic, the free evaluation copy, to fulfil all your network management needs. After a period, it will reduce functionality but still do nearly everything yhou will require. I use the paid pro version and I love it.
Network Magic will provide you witdh a license for up to 5 computers. It will run from any or all.
Give it a spin
I hope this helps you
a
Posted on Sep 26, 2009
techresolve
  • 109 Answers
SOURCE: Can the Belkin F5D8236-4 v3 router be connected to
Yes they are compatible, go ahead you can do it..
Posted on Feb 02, 2010
  • 37 Answers
SOURCE: Netgear router with Zyxel P600 - does not work
Reset and reconfigure the router.
Posted on Mar 06, 2010
  • 3 Answers
SOURCE: zyxel modem and wrt54g modem
1 first thing you do, go to web based utility 192.168.1.1 login to the zyxel modem....then go to tool => configuration => reset.....
2. configure your router, go to web based utility 192.168.1.1 login ti the router....then go to basic set-up choose DHCP automatic confg... enabled dhcp 192.168.1.100
max dhcp user its up to you....
3. advanced routing choose gateway.....select set number 19 .... then interface lan and wireless....
4. connect all the cable attached.... then checked the status is connected.....
5. set your LAN into DHCP....
Posted on Aug 09, 2010
  • 31 Answers
SOURCE: Aztech HW550 3G problem is
An address of 169.X.X.X usually means connectivity issues from your computer to the router.
Try the following:
1. Connecting only the router to the computer, one of the 4 ports together not WAN or Internet. (so remove cable modem at this point).
2. Go to a command shell (cmd in Start->Run).
3. Type in ipconfig /release
4. ipconfig /renew
If you still don't have a proper IP try replacing the Ethernet cable, this can usually be a source of the problem. Also this usually works too, press and hold the Reset button for 10 seconds or so. This should revert the router to the factory defaults, and retry steps above.
Posted on Sep 01, 2011
I am computer illiterate. Someone gave me this ZyXEL P600 series. How do I use this, and what does it do?
Hello, Roger -
The ZyXEL P600 appears to be a wireless computer modem / router (WiFi modem / router.)
To use it with a computer, you will need Internet service (a paid internet service provider.)
See the instructions here (Establishing a Wireless Network):
http://support.brighthouse.com/Article/Connect-Computer-Router-6628/
In case the person who gave you the wireless router did not give you the instruction manual for it, the manual you can find here, may prove helpful:
https://www.manualslib.com/manual/1054123/Zyxel-Communications-P-600-Series.html
Personal opinion: Seek out reliable relative or friend who is knowledgeable about computers and wireless routers to assist and instruct you. You will need one-on-one help.
Best wishes.
Mar 07, 2018 | Zyxel Computers & Internet
I have EarthLink Internet is a zyxel p-600 can I connect a wireless router? And if yes what kind should I buy or can it be any wireless router?
If I read this correctly the Zyxel P600 is a wireless device? Take a look at this, is this your device: https://www.magnet.ie/wp-content/uploads/2012/01/ZYXEL-install-and-wireless-set-up.pdf OR HERE: http://www.zyxel.com/products_services/p_660h_series.shtml?t=p You can add a second wireless device, if you want, by using a port on the P600, is that what you are asking? Depending on what you want to connect, the wireless adapter specs, to the wireless? B, G, N, AC wireless?
Apr 13, 2013 | Computers & Internet
I was helping a friend who has Earthlink DSL (a ZyXel DSL modem) to get her Linksys WRT160N wireless router working with the Earthlink modem. No luck. Earthlink won't help unless you pay $7.95/mo with a...
Hello mcneel,
The router should use the ZyXEL P600 as it's DHPC Server. And review/update the ZyXEL WAN configuration as follows:
• Log on to the ZyXEL P600 browser configuration interface: 192.168.1.1
• Enter username/password: Default is username:admin - password:1234
• Click '+' by Network in the letf-hand panel
• Click WAN
• In the Internet Connection tab, select the following options:
Name - (Any Name)
Mode - (Routing)
Encapsulation - PPPoE
User Name - (ISP login username eg. MyName@isp.com)
Password - (ISP Login password)
Service Name - (Leave Blank)
Multiplexing - (LLC)
Virtual Circuit ID
VPI - (Leave Blank: Issued by ISP)
VCI - (Leave Blank: Issued by ISP)
IP Address
Obtain an IP Address Automatically - ([X] Check this option)
Static IP Address - (Not Selected)
IP AddressI - (Leave Blank)
Connection
Nailed-Up Connection - ([X] Check this option)
Connect on Demand Max Idle Timeout sec
• Click 'Apply' button
• Close the browser configuration interface page
Finally, this link to the EarthLink DSL FAQ Setup Installation and Configuration page might offer some useful suggestions:
http://www.dslreports.com/faq/earthlink/30_Setup_Installation_and_Configuration
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 04, 2010 | Zyxel Prestige 645M (AM408405) Bridge
Im using zyxel p600 : problem from router then to d link switch why one PC will connect... 2 pc is network and ok.. only internet connection has problem .. only one PC is connected ..ty
Only 1 PC is able to go online. check the IP address on that PC.
and make sure that it is a private IP address. You have a switch also.
why do you need a switch if you have only 2 computers in the network.
If you have a router then you can connect both the computers directly to the router.
Click Here for more info about networking.
Oct 07, 2009 | Zyxel Computers & Internet
How to bring back the router function of zyxel P600 w/o password
You can simply reset the device to factory defaults. There's a reset button at the back of it. Hold it down for 30 second with the power on. That will reset the unit back to router function.
Jun 11, 2009 | Zyxel Prestige 600WH Wireless Router...
Zyxel modem and wrt54g modem
You need to put the zyxel p600 into bridged mode
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Zyxel password problem
wy do the signal be go in each moment ?
what is the problem?
May 20, 2008 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
