Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62525 very dark picture - Mitsubishi WD-62525 62" Rear Projection HDTV
  • 335 Answers
Change the lamp, you can get one hear CLICK
http://tvtechwork.webs.com/
Posted on Nov 12, 2010
Adjusting the color
Maybe convergence problem. Seek honest TV tech
Nov 12, 2013 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi 62525 static on screen more noticeable with dark background cleaned filter and replace lamp
A few of these (not sure if this model) have two mirrors inside--stupid idea and only a few had that--.
If this is the case here--little mirror (I mean LITTLE) is at bottom pointing up from the optical lens--gets dust and such from the fans= picture gets darker to the point where brightness is very diminished.
Mitsubishi can tell you if it has two mirrors (the large one in rear of set must not be touched and never needs cleaning as any finger prints etc will show in the picture.
If two mirrors I can tell you what to do--15 minute two person job.
Apr 03, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Feb 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Scrolling lines
problem with the Picture tube.set graphics properties to check.
Jul 06, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 BLUE SCREEN NO PICTURE NO SOUND
I had the same problem and I found that it was 2 caps on the power supply board. I had both caps replaced and it worked perfect. While it is apart see if any other caps are bad( if they are puffed up in the center they are bad).
Jun 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
My samsung dlp picture is dark, and if i turn on game mode the picture will lose color and become black and white.
you need to replace the lamp, and after you put it on game mode, go in and adjust the pick settings see if that helps
Jan 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Nov 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
