Question about Kohler Plumbing
My kohler faucet has a round stem nut with 2 flat sides.. cannot get bonnet cover off...any ideas
5 Suggested Answers
SOURCE: dripping faucet
Take a cloth and lay over the top of the stem so as not to damage it. With pliers, grasp the top of the stem and turn it a quarter turn counter clockwise. The stem should lift right out.
Posted on Mar 14, 2009
jj505
  • 195 Answers
SOURCE: kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Posted on Mar 16, 2009
  • 94 Answers
SOURCE: can't get stems out after I take off the bonnet of my delta fauc
you will have to gently pry them up and out,or grasp real good and work them out.nothing else is holding them down.
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: Greetings, I have kohler
That is a common problem and one that is very hard to fix once the water has been leaking for a time...the leaking water will leave a mineral residue that will keep you from being able to adjust the brass nut that you say will not move....
What you really need to do to stop the leak is to turn the brass nut down, or tighter to put more pressure on the packing around the stem to keep it from leaking...
If you cannot turn the nut anymore then you have no choice but to replace the faucet... if you force the brass nut too hard you will break the faucet anyway...
I have tried to use a penetrating oil like PB Blaster or WD-40 with limited success...it maybe worth a try...just be careful that over spray and run off do not ruin the finish on the sink...
heatman101
Posted on Jun 22, 2011
What is the the bonnet nut?
Also known as a collar, it holds the faucet stem in place.
Jan 10, 2015 | Plumbing
How does the bonnet on the kohler K-10430 come off?
After removing the oval button cap on the back of the handle loosen the set screw behind it and pull the handle up. The bonnet is threaded so hold the faucet body with one hand (I used a gel hot pad for a better grip) and turn the bonnet counterclockwise. Be careful not to let the entire faucet body turn or it may loosen the bottom bolt that keeps it pulled down onto the base o-ring. Then remove the nut in the same manner and you can simply pull the valve body straight up. To install just reverse this procedure.
Aug 09, 2011 | Kohler K-10430-VS Fort½ Single Lever...
I have a 2 handle bath faucet and am trying to remove valve. Can't turn nut either way. Any recomendations to help loosen nut? Which way does the nut turn? The brass nut and stem are pretty green. Been...
righty tighty, lefty loosey. if its too tight for wrench youll need a deep socket wrench that will fit it.my hats off to you. kohler makes a good faucet,if stem is shot you can find new ones at lowes.seat is also replaceble
Jan 26, 2011 | Kohler Forte Two Handle Centerset Lavatory...
How does the cartridge come out of the Kohler K 14030 single handle faucet?
Turn the water off to your Kohler K-14030 faucet under the sink. Open the the faucet to make sure the water is completely shut off. Remove the small setscrew cover from the backside of the faucet handle. You should be able to remove it by hand. Insert an 1/8-inch hex wrench in through the opening and into the setscrew. Rotate the setscrew counterclockwise three full turns; you do not need to remove it. Lift the handle off the faucet. Unscrew the bonnet nut, or cover, from on top of the cartridge retaining nut; counterclockwise until removed. This nut should be remove by hand as well. Use a large adjustable wrench to unscrew the cartridge-retaining nut counterclockwise until removed. Grasp the cartridge stem with pliers and lift it out of the faucet body. You may need to gently rock it back and forth until the suction from the seal ring releases.
Dec 27, 2010 | Kohler K-10430-VS Fort½ Single Lever...
Kohler fairfax k12175 cp took out button plug and screw - lever handle and bonnet won't come out - how do I get them out
Place a few drops of vinegar into the screw hole and wait a little bit. Try removing the handle again, sounds like it is just stuck on the cartridge stem. The handle should come off first, and then the bonnet. Here's the parts breakdown for your faucet from Kohler.
Sep 07, 2010 | Kohler Plumbing
Water leaking at handle when turned on
1- Hanldle may have a cap that will come off to access screw to loosen or allen screw on the handle to remove it.
First thing you can check remove handle and make sure the nut that holds stem down is not loose. You can tighten it and try this first just replace handle turn on and check for leaks.
If not please go to step 2 in removal of stem
2- Cut water off and remove handle to gain access to stem. Next remove stem by untighting nut at the base. Remove stem and replace o rings on stem about middle of it. That will stop water from leaking at the base.
May 19, 2010 | Kohler Fort© Widespread Lavatory Faucet...
Handles are completely stuck. I'm thinking due to Calcium build up. Can't move then at all.
remove the chrome covers from the handle and loosen the nut that pushes the seal around the stem to keep it from leaking. Then try turning the handles. if they still don't turn, take the nut all the way out and remove the stem from the faucet. This will allow you to wire brush all of the corrosion off the faucets. Use a good plumbers grease and put it on the stems before replacing them. do not overtighten brass nut.
Nov 29, 2009 | Kohler K-10272-4A-CP Fort½ Widespread...
Dripping faucet
Mar 14, 2009 | Kohler Model 102704A: Fort® Centerset...
Unable to pull spout to replace O'Ring in Kohler Faucet F10416
They just pull out, sometimes things get stuck and I cant get them lose as a plumber and you just have to buy a new one...dont feel bad
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
44 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
