Question about Amcor Heating & Cooling
Helo ! I have a Amcor PLMB15KE-410 ! I have a problem i cleen the air filter check the compressor gaz is no problem! Bat don't freez nice ! help me please ! my e-mail --- rui_santos22@hotmail.com
5 Suggested Answers
  • 423 Answers
SOURCE: I am looking for an exhaust hose kit for Amcor portable air condi
While you may find a kit specific for your portable air conditioner, it would be far easier and faster to simply measure the diameter across the exhaust port on the back of the unit. In US measurement, it may be 4 inch or 5 inch across.
Go to a hardware store (a quaint local one or a Home Depot if you must.) They will have a kit (for clothes dryers) that will most likely include the flexible tubing and two clamps. They also will have separate/bulk flexible tubing and clamps available.
Depending on how permanent the air conditioner installation is, the same hardware store will have exhaust outlets that can go through the wall and probably fit into a partially opened window.
Please post back here with further questions or clarifications on your problem.
Good Luck!
Posted on May 08, 2009
  • 384 Answers
SOURCE: I have an AMCOR 1400E
dear sir
if your aircon compressor is working and it,s not getting cold then it can be cause of leakage in aircon system then need to refill freon on your system .
please contact to your area amcor dealer for get the benefit of your warranty period(if it is in under warranty)
thank you
hope answer the question
Posted on Sep 25, 2010
heatman101
  • 43501 Answers
SOURCE: my lg 15000 er air conditioner is blowing hot air
The unit is probably low on freon and so it is running too cold....this trips the freeze stat and shuts down the compressor till it warms up and you reset it by turning it off and then on again...
The unit will need to be recharge or replaced...
Here isa tip that I wrote about how to add refrigerant to a air conditioner or coolingsystem
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 27, 2010
ynogami21
  • 670 Answers
SOURCE: I OWN A AMCOR AF11000E,
Have you checked the Freon level?
If the compressor kicks in but there is no cold air coming out of the a/c the next thing to check would be the Freon level.
If the Freon level is not sufficient or has depleted then it needs to be refilled. Check what type of Freon you compressor is using the most generic is R-14 or R-12.
Check if there's a cap for the condenser coils because some units does not have it.
To refill you must make a hole to the coil and use some hose with a pressurize small compressor to transfer the CFC from the Freon Tank.
You would need to have a gauge so you could measure the amount of Freon that you will transfer.
Once the transfer is successful you would need to use an acetylene torch and a metal patch to close the hole that you made and make sure that it is sealed so the Freon won't leak.
Hope this helps!
Posted on Aug 15, 2011
I need the Owner Manual for the Amcor KF9000E. I just got this given to me and I need to know how to hook it up for inside my Motorhome. Thanks Diana
PLM9000E-12000E-15000E manual.indd - Amcor
www.amcorstyle.com/pdf/PLMBmono-410-IM-GB-060517.pdfThank you for choosing this innovative Amcor air conditioner. We suggest that you keep this manual in a ... carefully read these instructions to maximise this product's performance. For over 50 years Amcor has specialised .... the remote control: a user friendly approach to your comfort. In order to direct the air flow to a lower ...
http://www.amcorstyle.com/pdf/PLMBmono-410-IM-GB-060517.pdf
Apr 02, 2018 | Amcor Heating & Cooling
How do i add refrigerant to a amcor kf900e portable air conditioner"
The compressor picks up the gas that is bringing the heat removed from the house to be compressed to liquid and cooled in the condenser coil When running the compressor is very hot. When the freon is low the compressor will be cooler because it doesn't have as much heat to compress. To add freon you must add a service valve to the low pressure line.
Aug 02, 2014 | Amcor KF 9000 BTU Silver Portable Air...
Filter frozen
This can typically be caused by two items, low refrigeration gas or insufficient air flow. I would shut the unit down, unplug it and let it set for a day to thaw out. Clean all the air passages and replace the filter. Plug it in and turn it back on. If it continues to freeze you probably have either low refrigeration gas or a fan that is not operating properly.
Feb 17, 2014 | Amcor Dehumidifiers
My lg 15000 er air conditioner is blowing hot air i could hear compressor starting for five minutez of cooling the n shuts off and hot air again i have cleen filtered and cleaned coils inside part
heatman101
Sep 27, 2010 | LG BG8000ER Air Conditioner
The unit will not produce cold air. It only pushes out room temp air. Altough I am not an expert, I think it is the compressor, or the tempature control unit (thermostat?) The unit does seem to make an...
I have a Amcor AF 1200E air conditioner, it only blows warm air and it is real dirty on inside filters, we took out 3 filters but there is still dirt on filters behind these, do we take it apart to clean, I would like a manual , do youknow where I can download one at? thanks
Sep 06, 2010 | Amcor AF9000E Portable Air Conditioner
I have an AMCOR 1400E and my compressor kicks on and gets very hot but no cold are comes out of the unit, I think i may have a bad compressor and don?t know who to call about the warranty since amcor is...
dear sir
thank you
Aug 30, 2010 | Amcor PLM-14000E Portable Air Conditioner
Compressor kicks off before reaching temp in heat mode
Hi; Does Your system have an air filter(check and clean). Or You could have a problem with Your tstat. Do You still have a warranty..alpharome416
Jan 21, 2010 | Amcor A12000E Nanomax Portable Air...
No power to portable air condition
If the filters are clogh with dirt , the unit breaker will shut it off ,it's avery common problem , but if after the filters were cleaned it keeps shutting off , could be a bad fan motor or the compressor itself could be grounded.
Oct 25, 2009 | Amcor Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
