Question about Logitech OEM S220 2.1 Speaker Black Computer Speakers
My speakers stopped working. The yellow light on the volume control is went out. I have checked to make sure everything is plugged in properly and that the power is in the "on" position.
    Brigadier General:
  • 10,406 Answers
> the light went out
Either the light itself is broken, or the speakers are not getting power, and so the lamp cannot light.
Try the speakers in another computer.
Or, buy a replacement set of speakers.
Posted on Nov 12, 2010
They worked for a long time, now all the sudden they aren't working. The main speaker it's powered on; however the green light is no longer lit and no sound is coming from them. Checking the...
possibly corrupted or missing sound drivers
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
if you dont have a motherboard disc you will have to download the drivers
Aug 29, 2011 | Altec Lansing ACS 54 Computer Speakers
My speakers are not working. I made sure everything is connected properly. The speakers do not even show up under my sound device panel.
also
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell A215 Computer Speakers
I have a set of Bose computer speakers and they seem to have just stopped working, everything on my computer says they are working fine and when I plug them into my laptop they work, so what could be the...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
hope this helps
Jun 24, 2011 | HP Audio Players & Recorders
My speakers phillips ambx premium kit was recently bought and all was well, with everything working fine but a few days ago the lights have stopped working due to not being registered on the ambx...
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Jun 11, 2011 | Philips SGC5103BD 2.1 Speakers
Went on vacation, came home and now speakers won't work. subwoofer blue light is on and everything is connected right. what could be the problem?
also
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
May 29, 2011 | Harman Kardon SoundSticks Computer...
I had reformat my PC .. because it wasn't working out .. i was not able to save all the drivers .. as in ALL .. when i finished reformatting my PC .. I discovered that it had no sounds at all .. My PC is...
also
hope this helps
Apr 13, 2011 | Computers & Internet
My sound went out on my computer. At first it sounded distorted. like talking through a helium balloon and then it just stopped working all together. My sound is on and everything is plugged in. And the...
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
also
hope this helps
don
Feb 18, 2011 | ASUS Computers & Internet
Speakers are plugged in correctly, lights on but still no sound
Check your output jack again and make sure its on the green jack
and also check your speaker wires, if okay then check this;
For Windows XP;
  1. Go to Control Panel
  2. Sounds and Audio Devices
  3. On the Volume tab under "Device volume" check that sound is NOT muted
  4. Adjust volume control
  5. Check "Speaker Setup" under "Speaker settings" under the "Advanced" button
For Vista:
  1. Control Panel
  2. Sounds
  3. Select Speakers then properties
  4. Make sure device is enabled
  5. Test sound
  6. Adjust volume controls
Under Device Manager make sure that under your sound card that you dont have a yellow exclamation. Yellow exclamation indicates you need to install the correct driver.
Jan 18, 2009 | E-Machines T6420 PC Desktop
Remote Control Repair
Open up your controller and look for 4 Wire! Green, light green, blue and yellow! Green and yellow is for power i guest! Light green and blue is for bass. 4 together max everything!
Dec 01, 2008 | Audio Players & Recorders
Sound
Make sure your volume is not on mute. If the speaker icon on your lower right has a red x means its on mute. To test go to control panel and double click sounds and test. If Windows sounds work without speakers then problem is with speakers. Make sure volume is up, make sure its properly connected to correct output jack (usually green or light green). Also make sure speaker power on. If those things are correct check your device manager ( right click my computer) select "manage", click on "device manager" and on right pane check to see if theres any yellow exclamation, question mark or red x on the sound device section. Yellow exclamation or question mark means to update or install correct drivers. Check your speaker box if it comes with a CD.
Jul 29, 2008 | Dell Inspiron 530s Desktop Computer...
Logitech OEM S220 2.1 Speaker Black Computer Speakers Logo
256 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
